Hi,
I have 2 PCs, with Outlook 2003 and OL 2007, and I have created a custom form based on a mail from the Inbox ("IPM.Note.MyForm"). I need to have it as the default form used in my Outlook, when I open any mail received in my inbox.
I have published it in the Inbox folder (I can see it in "Tools-Options-...-Manage Form") and I have used the Forms Administrator (with "IPM.Note.MyForm") to modify the registry (office\11.0 for OL 2003, 12.0 for 2007).
However, when I receive a mail it is not open using my custom form. Must I do sth. else?
*** Other test - questions:
- If I send a mail from a PC with the registry modified ('compose'), this mail is opened using my custom form!!!, even if I have not modified the registry (in the registry I can see the default "IPM.Note"). I suppose that is because the form to use is in the mail sent, and I just must have it published...
- Is it right that the inbox mail icon (in the previous case) is different from the envelop? It is like a 'note', is it related to 'IMP.Note'? Related to that, in the Inbox folder properties, I can see "When posting to this folder, Use: 'IPM.Post'... ¿? Which one is the correct? I thought it was 'IPM.Note' for mails...
- Using a
VB project, I have:
Set oSession = CreateObject("Redemption.RDOSession")
Set oInbox = oSession.GetDefaultFolder(olFolderInbox)
MsgBox "oInbox.DefaultMessageClass: " & oInbox.DefaultMessageClass
and it it 'IPM.Note', not the custom one...
Could you help me? Thanks in advance
Diego
