problems loading WinXP
Currently Active Users: 2450
Discussions: 203,414, Posts: 2,407,331, Members: 248,935
Old February 15th, 2009, 01:21 AM   Digg it!   #1 (permalink)
Exclamation
I am trying to load Windows XP onto a new hard drive from a CD Rom, and it keeps stalling at about 8% of the files loaded.
All parts are used, and have not been used together in the past:
ASUS A7M266 motherboard
AMD Athlon XP processor
IBM 16GB HDD, Model: DTTA-351680 E182115 S
256 MB PC2100 RAM
fat32
CD ROM 52X MAX
Power supply 145 Watt max
Any suggetions that you might have will be appreciated.
Thanks - YOYOCOMPUTERKID
Last edited by YOYOCOMPUTERKID : February 15th, 2009 at 01:54 AM. Reason: additional information
YOYOCOMPUTERKID is offline   Reply With Quote
Old February 15th, 2009, 06:30 AM     #2 (permalink)
Ride 'em Cowboy
Dust n dirt on the cd or cd drive can cause this.
Have you hugged your kid today??
Steve R Jones is offline   Reply With Quote
Old February 15th, 2009, 11:48 AM     #3 (permalink)
Unless its is a hardware problem/heat problem it is probably going to be the CD.
Intel Q6600. 8800GTX x2 SLI. 2Gig DDR3 1333 ram. 500Gig Hard drive. XFX 790i
jamhough22 is offline   Reply With Quote
Old February 15th, 2009, 11:58 AM     #4 (permalink)
Pump you sucker! Pump!
Chuckiechan's Avatar
It could also be bad memory.
"We shall fight in the air, we shall fight on the landing grounds, we shall fight in the fields, we shall fight in the hills -- for 18 months. Then we start packing for home." Krauthammer
Chuckiechan is offline   Reply With Quote
imagemixer loading problems narnies Technical Support 2 June 11th, 2008 06:48 PM
PC Shuts Down at WinXP Loading Screen b6fx Technical Support 4 April 1st, 2008 09:22 AM
XP Loading problems britrb Applications and Operating Systems 17 April 22nd, 2007 04:51 PM
Farcry Loading Problems Brian15 General Gaming Discussion 6 August 19th, 2004 08:39 AM
Problems with loading bhath19 Technical Support 16 May 23rd, 2003 05:35 PM
Is It Just Me? (3710)
nVIDIA GTX 260 vs ATI 5770 (5)
Superbowl commercials (The green po.. (15)
and she wanted to be VP? (33)
GPU upgrade from 8600 GT (8)
New PC Heavy Gaming Rig (8)
Need for Speed Shift (7)
[F@H Chat]2/6/10 New thread for ya'.. (21)
Best route for upgrade (several opt.. (5)
Motherboards with 2 PCIE x16 slots (8)
I want to buid a pc with this case (14)
Graphene transistors promise 100GHz.. (7)
Animated GIFs don't animate? (13)
Upgrading (5)
BSOD - IRQL not less or equal - HELP! (0)
Unable to find LAN (7)
Best route for upgrade (several optio.. (5)
[F@H Chat]2/6/10 New thread for ya' s.. (21)
SpeedFan Temp Monitor Help (2)
should i upgrade whole pc or just vid.. (2)
WEBCAM / XP / XP64 / VISTA (7)
routers and switches OPERATING SYSTEM.. (0)
One dumb nube and a cisco 3550 (1)
120mm fan on top of case??? (12)
Is my hard drive going bad? Please h.. (2)
rsync over passwordless ssh in a cron.. (4)
HD5870 Question (15)
Wii at buy.com for $374 - Carnival Sm.. (7)
Deleted email addy keeps bouncing bac.. (1)
Laptop - HDTV Connection Using HDMI C.. (1)
Video Format Total Solution: How to C.. (0)
How Good is This $450 MSI Laptop? (2)
wireless connectivity (0)
My 9400GT's fan is screwy (2)
Graphene transistors promise 100GHz s.. (7)
