Thread: x86 (32-bit) on x64 (64-bit)
October 7th, 2011, 10:28 AM #1Member
- Jun 2011
- 48
Hi guys,
I am getting this error, "This version of the file is not compatible with the version of Windows you're running. Check your computer's system information to see whether you need an x86 (32-bit) or an x64 (64-bit) version of the program" when i tried to run turbo c++ on my windows vista ultimate 64 bit os.
I am also getting the same problem when i tried to run the command promt executable c program (the .exe file made by using turbo c) and "the castle of wolfenstein" game.
So how can i run them on my os??
pls help...
Thanx in advnc...
October 8th, 2011, 11:10 PM #2
My first guess would be it's trying to use files in the "C:\WINDOWS\system32" directory. On a 64-bit OS, those are actually 64-bit files. You may need to point the game to pull files from the "C:\WINDOWS\SysWOW64" directory if it's possible.
If that's not possible, you might try installing Virtualbox and installing a 32-bit version of Windows XP.This signature intentionally left blank.
32 bit to x64 driver compile
By ibanez_bass in forum General Tech DiscussionReplies: 5Last Post: February 2nd, 2009, 09:51 PM -
Problem with 32 bit PHP on windows server 2003 64 bit edition
By TinMan486 in forum Webmastering and ProgrammingReplies: 4Last Post: August 19th, 2008, 10:04 AM -
x64 bit key?
By eneki in forum Applications and Operating SystemsReplies: 3Last Post: July 19th, 2005, 11:31 AM -
Microsoft Windows XP Professional X64 - 64 Bit Edition
By md300 in forum Applications and Operating SystemsReplies: 1Last Post: May 20th, 2005, 12:56 PM -
x64 bit Windows
By skeltonjoe in forum General Tech DiscussionReplies: 9Last Post: April 30th, 2005, 12:38 PM
that was easy, if only deleting the partition was that simple.
