Results 1 to 6 of 6
    Jan 2012
    3
    MS Word table text does not flow to next page
    Hi all,
    I have a similar problem to that stated in MS WORD Table will not continue to next page though not exactly the same. My table goes over a number of pages and has multiple columns and rows. The problem is that when the text exceeds the height of the page, the text disappears and does not continue on to the following page. The next page just shows the next row in the table.
    After reading this thread I disabled text wrapping in the table but that hasn't made a difference. Is there something else I should do from here? The "Allow text row to break across pages" option is greyed out.
    I would be eternally grateful for any suggestions!
    West Haven, Utah
    32,647
    Quote Originally Posted by sphynx25 View Post
    Hi all,
    I have a similar problem though not exactly the same. My table goes over a number of pages and has multiple columns and rows. The problem is that when the text exceeds the height of the page, the text disappears and does not continue on to the following page. The next page just shows the next row in the table.
    Is the text direction anything other than horizontal in one of the cells? This will cause the "Allow row to break across pages" option to be grayed out (using Word 2010).
    What version of Word are you using?
    Jan 2012
    3
    Yes, I do have both horizontal and vertical text directions. It would be difficult to remove the different text directions though, just as it makes my table neater. I am using Word 2010.
    West Haven, Utah
    32,647
    If you change it to horizontal, the option won't be grayed out any more. If that's unacceptable, you may have to insert another cell and manually copy the content that won't fit into the new cell.
    Jan 2012
    3
    Yep, I changed the text all to horizontal again and the option was no longer greyed out. Ticking that box fixed my problem.
    Thank you so much guys! Much appreciated!
    West Haven, Utah
    32,647
    Glad to hear that it worked.
  1. Forcing 2 page Word document to print on 1 page (HP Printer)
    By stephenco in forum General Tech Discussion
    Last Post: October 5th, 2008, 09:28 AM
  2. MS Word Table in Form
    By Smidley in forum Applications and Operating Systems
    Last Post: June 30th, 2005, 09:13 PM
  3. Table Help - Word OR Excel
    By Bill in SD, CA in forum Applications and Operating Systems
    Last Post: May 5th, 2005, 05:48 PM
  4. MS WORD Table will not continue to next page
    By Marvinator in forum Applications and Operating Systems
    Last Post: February 25th, 2005, 06:37 PM
  5. Table Help and Page Layout Help
    By fufiter9246 in forum Graphic Design and Digital Photography
    Last Post: June 27th, 2003, 07:49 AM
