Thread: Wireless Domain Connections
February 10th, 2012, 04:06 PM #1
Hey all,
Question for anyone who works on a domain and has wireless users...
How do you handle the wireless connection to the network not being available before login? So any computers regular user would have their credentials cached and when they log in, the network comes up and syncs and life is peachy, no problem.
However when a new user sits down at that machine and attempts to log in, they cannot. No connection to the network until wireless comes up and it won't come up till someone logs in. Catch-22.
Apparently some wireless cards' software allows for always on type connections, but we use a variety of wireless cards, USB and built in alike. No way to use that, as our secure connections use the Windows Zero Config setups.
Does anyone have any ideas or suggestions?
Thanks!
Undeadlord
February 10th, 2012, 05:04 PM #2
Which MS os are you using?
February 10th, 2012, 05:32 PM #3
Windows XP and Win7 (x86 and x64 for Win7)
February 10th, 2012, 09:48 PM #4
I guess before you do that, how does the computer authenticate to the wireless network? Dot1x?
This might help try a test group policy with a laptop that makes the computer wait for the connection
"Computer Configuration\Administrative Templates\System\Logon\Always wait for the network at computer startup and logon"
Test that out and see if that clears up your issue
February 13th, 2012, 12:16 PM #5
I think I found a solution for this, initial testing seems to have it working, but here
Wireless and Windows Domain login? - Wi-Fi Planet Forums
about third from the bottom,
I had the same problem. What worked for me was setting the wait for network setting in group policy as mentioned above by M/Q and then setting a wireless profile into the group policy.
To set a wireless profile in group policy navigate to Computer Configuration>Windows Settings>Security Settings>Wireless Network (IEEE802.11) Policies
Then right click the blank space on the right and create a new wireless profile. This will add the wireless profile to all accounts on every computer affected by that policy, a global wireless policy so to speak. When this is done my wireless clients seem to make a network connection prior to logon. I am even able to connect via VNC to a client that has just had a fresh reboot and has not yet been logged on.
February 13th, 2012, 01:28 PM #6
Thanks for posting an update!
Simultaneous wired and wireless LAN connections
By osprey4 in forum Networking and InternetReplies: 26Last Post: March 11th, 2011, 02:18 AM -
Vista wireless connections broadcasting as rogue DHCP servers
By bm159486 in forum Networking and InternetReplies: 6Last Post: April 10th, 2009, 04:11 PM -
Remove Hidden Wireless Connections
By cpearson1984 in forum Networking and InternetReplies: 11Last Post: January 7th, 2008, 01:57 PM -
blocking one of 2 wireless connections help!
By suckmykiss in forum Networking and InternetReplies: 3Last Post: January 17th, 2006, 08:36 AM -
Networking and Broadband (wireless connections)
By melkor6925 in forum Networking and InternetReplies: 2Last Post: August 25th, 2003, 10:09 AM
So I decided to buy windows 7 home premium-upgrade instead of the ultimate version-upgrade because I wanted the 'XP Mode' featured in pro/ ultimate versions of 7 but it came to mind that ill dual...
Upgrading windows XP 32-bit to...
