Results 1 to 13 of 13
Thread: Window 7 64 bit
    Member Shoes's Avatar
    Joliet Il
    107
    Window 7 64 bit
    Can i use windows 7 64 bit with this hp d-branded system here is the link
    HP De-Branded Athlon II X2 220 2.8GHz 2GB 750GB DVD±RW DL No Operating System HP TS-0006P-AMDX611
    Jan 2003
    Outside the box
    8,489
    4
    You might have to track down some of the drivers but other than that you should be fine
    Millwright stroyal's Avatar
    Dec 2002
    New Hampshire
    8,063
    Yes.~
    But unless you are planning to have more than 4 gig, you don't need it.
    It will run on 2 gig, but 4 gig is generally considered minimum, with a 64 bit win7
    Hard Sayin Not Knowin
    Dec 2002
    New Hampshire
    8,063
    Quote Originally Posted by RicheemxX View Post
    Forgot about drivers.
    Jan 2003
    Outside the box
    8,489
    4
    I'd agree that 64bit really isn't needed but there really isn't a reason to not go ahead and put it on there now.
    TBH drivers on a newer desktop system usually aren't that big a concern but sometimes these HP systems have OEM hardware in there that might be a PITA to find the right ones for. If something doesn't happen to auto install you'll just have to look around the HP site, Google or even the component manuf. site.
    Dec 2002
    New Hampshire
    8,063
    I agree, unless they never go to 4gig, it might be more sluggish than 32bit.
    Myself, I wouldn't even consider 32bit. The price is the same and RAM, is cheap.
    That part number doesn't work on the HP sight.
    It might be there, as the message 300 items found with that number.
    Unless you can find drivers, I wouldn't buy it.
    Jan 2003
    Outside the box
    8,489
    4
    Wow straight from the product description
    Device Drivers not included (Drivers may be difficult to find)
    Dec 2002
    New Hampshire
    8,063
    I'm changing my vote to NO.
    1 It is de-branded.
    2 It says "support by Geeks, and they have no support link.
    3 It also says "Device Drivers not included (Drivers may be difficult to find).
    Believe me, driver that are not available from the manufacturer, are a huge to impossible problem.
    Xp has a few, and I assume 7 will have a few, but others have to come from the manufacturer
    Minnesota
    17,433
    "Supported By: Geeks"
    Is reference to the warranty on the product too, not tech support.
    Minnesota
    17,433
    I would guess that it should install fine, based on this single review on newegg...
    Newegg.com - Refurbished: HP Debranded TS-0006P-AMDX611 Refurbished Desktop PC Athlon II X2 220(2.80GHz) 2GB 750GB HDD Capacity NO OS
    Assuming that person can be trusted. but they said they installed Win 7 64 with out a problem.
    Dec 2002
    New Hampshire
    8,063
    I was just being fascias, I didn't really thing they had driver support.
    Dec 2002
    New Hampshire
    8,063
    He doesn't say where he found the BIOS and drivers.
    Possibly, there are real numbers, on the computer/motherboard, and they are available at HP.
    I hate to think, you have to buy it to find out.
    HP Support & Drivers | United States
    Joliet Il
    107
    Thanks everyone for your input . I ordered this system from newegg and 4 gigs of ddr3 Crucial Memory. Just hope i can find all the drivers.
  1. Problem with 32 bit PHP on windows server 2003 64 bit edition
    By TinMan486 in forum Webmastering and Programming
    Last Post: August 19th, 2008, 10:04 AM
  2. Confused about 256-Bit vs 128-Bit Memory Interfaces
    By Player_13 in forum Graphics Cards and Displays
    Last Post: July 10th, 2007, 11:38 AM
  3. Help with ATI Rage dvd tv out 64 bit window xp video graphic card
    By flamestoner in forum Graphics Cards and Displays
    Last Post: November 7th, 2005, 07:48 PM
  4. Windows 9x question about 32-bit and 16-bit software installation
    By Nancy P. in forum Applications and Operating Systems
    Last Post: October 12th, 2004, 11:46 AM
  5. Replies: 13
    Last Post: April 14th, 2004, 11:59 AM
