June 14th, 2012, 08:50 PM #1Member
- Jan 2005
- 329
Weird Stuff - got no sound after pulling Hard drive.
C Drive did the "clattering pots" type noise - which is a far cry from no sound
So I figured it "went off into history" This is a Pentium 2 Data server with a Quantum AT Fireball Plus AS 3.5 series
As there is no year marking....those that know their stuff know this is in its teens years old. So failure was eminent as this was the "master"
This is what I guess happened. My Computer showed nothing on C drive.
Now I have put in another Hdd, out of an "E Machine" after pulling the other out as a paper weight.
This is on "cable select". It is the only drive on the 20 pin strip
Maybe I should have gone to master with the jumper---I do not know
However I first used MS to "FORMAT IT" and then loaded Windows XPpro on it.
Also I loaded the audio driver 7012 for SiS because that is the circuitry.
I am up to date with Win XP on its updates.
But no sound comes out of the PC speakers? I don't know why.
I checked the DEVICE MANAGER and only have a question mark regarding USB.
Speakers are connected direct to computer via a round pin on a black wire. (not usb)
Now, I could put the old Quantum in and rehook everything up as it was before,
but is that gonna fix anything ?(or am I just screwing around?)
I did download and install the SiS driver but checking in the DEVICE MANAGER sound I see that there is Legacy Audio driver/Audio Codecs/Legacy Video Capture/Media Control Devices/MPU-401 Compatible MIDI Devices/SiS 7012 Audio driver/Video Codecs
and none have a "yellow Question mark"
So....anybody got an idea what I missed? Cause the PC beep is just not doing it for me if you know what I mean.
Appreciate any insight into this.
The "asms" problem I got past but there is another problem plaging me now
Different machine, different problem.
I got a different XP disc and it continued to download from 39 minutes
Got to the music and animations and everything.
Now initially on that computer I just wanted Windows in and to leave what I had in there alone.
So this is just a "read the CD and do repairs or reload itself"
Hoping all my files would still be there. OK?
I get down to the finish with the NEXT buttons AND IT ASKS FOR A PASSWORD
SAY WHAT? Enter was the password. I did not put one in. How do I get around this roadblock Windows has put up.?
Right now the CD has finished reading. I do not care if I have to reload it again to do it again. There is no password.
Also the computer is not on line.
It has been shut down for 2 months already. I was hoping to get it back up and going.
All I know how to do is format C
It is all in NTFS so maybe DOS command Format C won't even work.
Bother, it P. me Off
Again, any help in this machine is appreciated. This machine is a Compaq Pentium2Last edited by friedemann; June 14th, 2012 at 09:04 PM. Reason: adding info
July 14th, 2012, 02:43 PM #2Member
- May 2012
- 122
What is the specs on the computer? I looked online and is it 100 MHz - 300 MHz?
July 15th, 2012, 12:49 PM #3Member
- Jan 2005
- 329
How to set up XP pro for a single user?
Got both former problems fixed on my own. How, I can't remember.
This PC "ECS"is loaded with all updates for XP pro I shut my machines off for the night.
So, on cold boot it goes as far as the point where my name is button(like it is a multiple user machine (which it ain't and won't ever be)
I just want to turn on the machine and go get my cereal and coffee and come back to a fully functional machine(as the antivirus, firewall and whatever it decides it needs loads. I just want it to get to desktop ready to go.
Direct me how to do that is much more preferable than me making an attempt at it. I do know how not to pick the winning Lottery numbers, if you get my drift.
July 15th, 2012, 01:34 PM #4
To disable the login prompt in Windows XP:
- Click Start > Run, type in:control userpasswords2and press [Enter].
- Uncheck the box for "Users must enter a user name and password to use this computer" then click Apply > Ok.
July 17th, 2012, 12:13 AM #5
Thanks ^^
◄ it is what it is ►
July 17th, 2012, 12:56 PM #6
July 17th, 2012, 01:23 PM #7Member
- Jan 2005
- 329
To Spyware Doctor
It did work. However in my first letter everything showed up as "regular type with no highlights" Why, only the PC knows. The second time I went to the letter I got the red highlighted words so I copied and pasted. Machine listened.
I know you guys are good
(well, better than me) who knows Dick and his sister Squat
I lucked out in finding the Techimo site
Thank you muchly
July 17th, 2012, 01:27 PM #8Member
- Jan 2005
- 329
I did have a second user
ASP.net What is that? I know I could Gaggle it but I am here anyways so might as well get the right answer
Weird Problem w/ my hard drive
By -DCP- in forum Storage RelatedReplies: 2Last Post: June 5th, 2009, 05:24 PM -
Weird problem with Hard Drive. Please help!
By superpig10000 in forum Storage RelatedReplies: 3Last Post: January 14th, 2007, 07:44 PM -
Hard Drive - Recovering Stuff
By lablkilz699 in forum General Tech DiscussionReplies: 1Last Post: October 9th, 2006, 02:20 AM -
Hard drive doing strange stuff - help!
By celebritymusic in forum General Tech DiscussionReplies: 3Last Post: March 5th, 2006, 02:02 AM -
CD-ROM and DVD drive both doing weird stuff.
By Ymer in forum Technical SupportReplies: 8Last Post: August 25th, 2003, 01:31 PM
It would make for a terrible weapon for the average mass murderer. A more appropriate gift would the The Anarchist Cookbook.
The perfect gift for an aspiring...
