Thread: 32 bit vs. 64 bit
August 24th, 2012, 02:43 PM #1
32 bit vs. 64 bit
I am thinking of build another system at home. This time i am considering a 64 bit system. If I build a 64 bit system, can I install a 32 bit OS, currently I still only have XP. If I install windows 7 64 bit, can I run 32 bit applications?
Thanks.
bdj
August 24th, 2012, 02:49 PM #2
To make this easy on you
32-bit and 64-bit Windows: frequently asked questions
August 24th, 2012, 02:51 PM #3Main PC: AMD FX-8350 / 16gb DDR3 1600 / AMD 7970GE 1200mhz Core & 1600mhz Mem / Win7 Pro 64bit
August 24th, 2012, 06:27 PM #4
to add to that, its nigh impossible to build a solely 32-bit system these days, aside from running a solely 32-bit OS.
Just about ALL CPU/Motherboards are 64-bit capable these days.i7 940//Corsair H60//EVGA X58 SLI LE//6GB Corsair Vengeance 1600MHz//2x EVGA GTX 560 Ti FPB SLI//NZXT Hale82 850W//CM 690 II Advanced//Win7 64//WD 74GB V-raptor, 750GB Black, 1.5TB Green
August 25th, 2012, 08:24 AM #5
I dont think software has kept up with the 64-bit trend as much as it should...just thinking, does hardware really benefit from 64-bit?
The Beatings Will Stop When Morale Improves
August 25th, 2012, 02:15 PM #6
most software, no. Software that does use 64-bit, yes. I have several 64-bit native programs, mainly 3D rendering stuff, and there is a noticeable speed difference in rendering capabilities, not necessarily a difference like a snails pace vs Warp 8, but it is there, and for stuff like rendering, anything that can drop times down significantly is a big help. Multiple CPU cores, Access to more RAM so less HDD Swapping of data, Decreased Render times, etc. Same can be said for Video and Audio editing apps, Photo Editing, etc.
and there are several other types of situations where it can be advantageous.
Gaming, some games could benefit from it, if they were actually optimized for it. there are games that have a 64-bit executable version, but I don't think their really truly optimized beyond having access to the beyond 4GB RAM barrier.i7 940//Corsair H60//EVGA X58 SLI LE//6GB Corsair Vengeance 1600MHz//2x EVGA GTX 560 Ti FPB SLI//NZXT Hale82 850W//CM 690 II Advanced//Win7 64//WD 74GB V-raptor, 750GB Black, 1.5TB Green
August 28th, 2012, 03:18 PM #7
I'm not doing graphic rendering, and I'm not into gaming. I was just wanting to upgrade my system at home. I do mostly e-mail, check on-line banking, write a couple of letters, etc. etc.
bdj
August 28th, 2012, 04:09 PM #8
the 32-bit OS is perfectly fine for you.
forget about whether the hardware is 64-bit capable or not, it will run 32-bit OS and software.i7 940//Corsair H60//EVGA X58 SLI LE//6GB Corsair Vengeance 1600MHz//2x EVGA GTX 560 Ti FPB SLI//NZXT Hale82 850W//CM 690 II Advanced//Win7 64//WD 74GB V-raptor, 750GB Black, 1.5TB Green
Migrating Win 2003 32-bit to 2008 64-bit
By MTAtech in forum Applications and Operating SystemsReplies: 5Last Post: September 30th, 2009, 08:53 PM -
Problem with 32 bit PHP on windows server 2003 64 bit edition
By TinMan486 in forum Webmastering and ProgrammingReplies: 4Last Post: August 19th, 2008, 10:04 AM -
Confused about 256-Bit vs 128-Bit Memory Interfaces
By Player_13 in forum Graphics Cards and DisplaysReplies: 4Last Post: July 10th, 2007, 11:38 AM -
Windows 9x question about 32-bit and 16-bit software installation
By Nancy P. in forum Applications and Operating SystemsReplies: 7Last Post: October 12th, 2004, 11:46 AM
Plan how to spend your whole day? Come here and get the awesome list to enjoy your favorite one. Criminal Minds Season 8 Episode 23 Masterchef Season 4 Episode 1 Game Of Thrones Season 3 Episode...
Watch After Earth Online
