Results 1 to 4 of 4
    Feb 2012
    8
    How To Delete Operating System Partition
    Hi there,
    I have been some technical problems for some time now. For about a year, I have tried to install Microsoft Office 2007 and Microsoft Office 2010. However, the installation process has never succeeded. Recently, in order to be able to meet the requirements for my computer classes, I re-installed my Microsoft Windows XP SP3, and I was able to successfully install Microsoft Office 2010 after I updated my new Microsoft Windows XP from SP2 to SP3.
    However, my main problem is the following. A couple of months ago, my sibling installed another operating system called Ubuntu. As such, at the time being, at the moment the computer starts up, there are three operating systems that show up. The first operating system, is the new Microsoft Windows XP SP3 I recently installed. The second operating system, is the old version of Microsoft Windows XP SP3 I have had for the past two years. And the last operating system, is Ubuntu.
    When I re-installed Windows XP, I chose, if I recall correctly, to install the new version on the D: partition (or the D: drive?). My question now, is how I can possibly delete the old version of Microsoft Windows XP SP3 as well the Ubuntu operating system. If someone could walk me through the process, I would appreciate.
    Thank you in advance for your assistance.
    Frick tony_j15's Avatar
    Mar 2003
    Joplin, MO
    14,115
    IIRC, when you go to install windows, it will give you the option of creating and deleting partitions. Simply delete the old partitions and create a new one with the entire space allotted towards it.
    Here's a walkthrough.
    Good job, friend-of-friends!
    Millwright stroyal's Avatar
    Dec 2002
    New Hampshire
    8,059
    You should have chose to delete all the partitions, and reformatted a single partition.
    Backup, before trying any of this.
    At the beginning of the set up, you delete the partitions, one at a time.
    After they are all deleted, then you format the single partitions.
    With Linux installed you will have to run "fixmbr" at some point to get the XP boot loader back.
    The few times I did it, I ran it after the install was done, and it wouldn't boot, as Linux won't know about the new XP install.
    You can also use a partitioning program, and delete the other partitions.
    Then run "fixmbr" at a command prompt, the get the boot loader, back from Linux (Ubuntu).
    If the second installation of XP is still showing in the boot loader, you just edit the boot loader. This is done in MY Computer.
    I had to edit out a second XP just a few days ago.
    I have never done this with both Linux, and a second XP, just either or, but it should be the same, or close.
    Partitioner
    The free one is good enough
    Free Partition Magic alternative & free Partition Manager Software for Windows PC, Workstation and Server - EaseUS.
    edit boot loaded
    How to edit the Boot.ini file in Windows XP
    Hard Sayin Not Knowin
    Feb 2012
    8
    Partitioner
    edit boot loaded
    Thank you for your posts to all, I managed to reboot everything and install a new Windows XP partition.
  1. Windows Operating System for Athlon 64 3000+ CPU - 32 or 64 bit Operating System??
    By stephenco in forum Applications and Operating Systems
    Last Post: February 26th, 2012, 05:34 PM
  2. How do you delete an operating system?
    By Gamer333 in forum Applications and Operating Systems
    Last Post: January 11th, 2008, 03:10 AM
  3. Delete one of the operating systems on my pc
    By mrsparky in forum Applications and Operating Systems
    Last Post: August 31st, 2005, 04:23 PM
  4. Replies: 8
    Last Post: August 17th, 2004, 06:57 AM
  5. Delete Operating System
    By $hocked in forum Applications and Operating Systems
    Last Post: January 4th, 2004, 09:02 PM
