Thread: Problem with Winrar
September 22nd, 2012, 04:00 PM #1Junior Member
- Sep 2012
- 7
Problem with Winrar
Hi every one,
I need help for the problem I faced with Winrar. I have a AVI file with 173MB. Since I was unable to send it via email, even with SkyDrive online files and documents, I decided to reduce the file size. I though Winrar could possibly be a good option. I right clicked on the AVI file and then clicked on “add to my archive”. A window appeared “Archive Name and Parameters”. I then selected fast as “compression method” and for another menu, “split to volumes, bytes” I entered 24mb. Then I pressed ok and then I saw hundreds of hundreds of Winrar files on my desktop, all 1000bytes. I have been trying to delete them with no success. I’m so much disappointed and would be very grateful if anybody could kindly give me some advice.
Many thanks,
September 22nd, 2012, 04:09 PM #2
September 22nd, 2012, 04:11 PM #3Junior Member
- Sep 2012
- 7
Thanks for your post. My problem now is how to get rid of hundreds of Winrar files on my desktop. Any adive will be highly appreciated.
September 22nd, 2012, 04:12 PM #4
They won't delete?
September 22nd, 2012, 04:14 PM #5Junior Member
- Sep 2012
- 7
I can delete them but there seems to be thousands!!!!!!!! each time I can select and delete as much as 136 items!!!!!!!!!!!!!!!!!!!!!!!!
Very dissappointed!!!!!
September 22nd, 2012, 04:16 PM #6
September 22nd, 2012, 04:17 PM #7Junior Member
- Sep 2012
- 7
so your suggestion is that to keep on deleting.
September 22nd, 2012, 04:18 PM #8
I'm afraid there is no other method, but to highlight as many as you can and delete them. If you hold the control key and select the files you can select more than one. just don't release the control key when you click a new file.
September 22nd, 2012, 04:19 PM #9
You might try moving the other items from your desktop into another location (temporarily), then go to the command prompt, go to that directory, and type DEL *.*
September 22nd, 2012, 04:23 PM #10Junior Member
- Sep 2012
- 7
I just wish there was an option in windows by which you could choose the file name and file type and delete all the selected files altogether.
Howste I can't find the command prompt. could you please let me know where I can find it.
I found command prompt bu tI can see
c:/documents and setting>my computer name
What commant i should give it to clean up only my desktop. I have already put my necessary desktop files into a temprary file.
will appreciate your advice
I could sort the problem out with the command prompt and directory and del*.*.
Many thanks Howste. This solution would never ever come to my mind. Thanks
so now, does any body know how to reduce a 174MB AVI file to 20MB?
Any idea on how to reduce the size of an AVI video file of 174 MB to maximum 20MB so it could be sent via email. ThanksLast edited by RicheemxX; September 22nd, 2012 at 05:31 PM.
September 22nd, 2012, 05:25 PM #11
I seriously doubt that'll happen! What service are you using that has such a small limit? There are other options out there like dropbox which will allow you to upload the file and then share it with whomever so they can download it. Or if you have an IM service like Yahoo Messenger you can generally connect directly to the user and send it over to them.
September 22nd, 2012, 05:31 PM #12Junior Member
- Sep 2012
- 7
I’m going to send this file to a group of my students whom carry different email accounts (e.g. gmail, yahoo, hotmail, etc), but mine is hotmail with presumably 25 MB limit. I also tried “Save File on SkyDrive” in hotmail but it does not work. Any idea?
September 22nd, 2012, 05:35 PM #13I'm not familiar with that option but if the file is already on your computer log into your skydrive account and upload it to skydrive and then share it.“Save File on SkyDrive” in hotmail
September 22nd, 2012, 05:36 PM #14Junior Member
- Sep 2012
- 7
will try this to see if it works
September 23rd, 2012, 03:35 AM #15Member
- Dec 2010
- Location
- Lebanon
- 310
September 24th, 2012, 06:13 AM #16
WinRar Problem
By AndreL in forum Applications and Operating SystemsReplies: 0Last Post: May 7th, 2012, 06:54 PM -
WinRAR
By EWeber19 in forum Applications and Operating SystemsReplies: 4Last Post: November 27th, 2011, 05:16 PM -
WinRAR Help
By Ed Dobias in forum Applications and Operating SystemsReplies: 9Last Post: March 9th, 2004, 03:51 PM -
WinRAR Help!!
By Creatures in forum Applications and Operating SystemsReplies: 11Last Post: February 4th, 2003, 03:59 AM
Is it snowing up there?
