Dual-Booting Around OS/Hardware problems ?
Currently Active Users: 1871
Discussions: 200,935, Posts: 2,379,206, Members: 246,300
Old July 29th, 2002, 04:48 AM   Digg it!   #1 (permalink)
Prof. of DooGlian Studies
MegalosSkylaki's Avatar
Here's the deal. I've been debating Win98SE or WinXP. The solution that struck me is obvious--use both.
I have some older cards (Video/TV/DVD) and and also a good USR hardware ISA modem that aren't supported by Win XP--or any OS past 98SE (ME for ISA) for that matter. Trust me--I've looked into it.
Now what if I install WinXP and also Win98SE on the same computer ? ?
Is thare any way of taking an ATI Video All-In-Wonder PCI Rage 128 and an ISA modem away from XP's "eyes" ?
And giving XP an external serial modem with voice-support for telephony, while 98SE enjoys the USR ISA Hard-modem. And running the older AIW-TV capture PCI gfx card under 98SE which won't work under XP.
(I also have a DVD "inlay" card which I'm hoping I can some milage out of.)
In other words, can I have in effect two computers in one box ?
And does it matter if the two OS's are on one HDD or two ?
Basically, it's the ATI Rage 128 AIW TV PCI Gfx card and the USR ISA modem I don't want XP to holler about.
MegalosSkylaki
MegalosSkylaki is offline   Reply With Quote
Old July 29th, 2002, 06:15 AM     #2 (permalink)
Go back to sleep
Creatures's Avatar
Send a message via ICQ to Creatures
sorry
but i have just one answer for this question
> And does it matter if the two OS's are > on one HDD or two ?
my Win98 and WinXP are not on the same HD and it works with
OsLoader
Try it, prehaps it works also with one HD
Creatures
Canon EOS 450D | Canon EF-S 18-55mm 1:3.5-5.6 IS | Canon EF-S 55-250mm 1:4-5.6 IS | Canon Speedlite 430EX II
Creatures is offline   Reply With Quote
Old July 29th, 2002, 06:21 AM     #3 (permalink)
lynchmob's Avatar
I think what you suggest is very possible:it would simply be a matter of removing the devices from the 2 OSs respective hardware profiles.
lynch
Seldom right,but never in doubt...
lynchmob is offline   Reply With Quote
Old July 29th, 2002, 08:38 AM     #4 (permalink)
ed
Centurion - From Canada
Centurion is offline   Reply With Quote
Old July 30th, 2002, 12:30 PM     #5 (permalink)
Dax_Brandy's Avatar
Send a message via Yahoo to Dax_Brandy
meg,
i got no problem with it. in my case, got XP and 98SE installed in one HDD but different partition of course. XP on NTFS and 98 on FAT32..
just make sure all your hardware is compatible with XP.
Dax_Brandy is offline   Reply With Quote
Is It Just Me? (2889)
Wireless Televisions. (6)
Obama the Muslim (14)
CPU fan stops spinning randomly (3)
wireless user (1)
windows 7 problem (1)
Modern Warfare 2 freeze (12)
favorit (1)
Regular Build (3)
Fire in DVD (2)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
