Results 1 to 9 of 9
    Ultimate Member aznlurkerz's Avatar
    Nov 2001
    Seattle, WA
    1,244
    How do I wipe a HDD running WinXP OS?
    ello's
    Basically, how do i wipe a comp running WinXP, is it possible to stick in the win98se boot disk and delete all the partitions, then reboot, Format the whole drive, and reinstall WinXP, and by doing so the partition will also be done during the installation correct?
    FYI - Getting rid of XP Home installing XP Pro.
    aznlurkerz
    i9300, lovin it!
    Senior Member sven222's Avatar
    Australia
    575
    yeah, what you said will work fine.
    but the winxp cd can be used, rather than the win98 cd.
    Member troyt75's Avatar
    Jan 2002
    Grand Marais,MN
    231
    What he said.
    Registered Linux user #316144
    Nov 2001
    Seattle, WA
    1,244
    Excuse me? what do u mean by the win98 cd, i dont quite fully understand.
    i9300, lovin it!
    Jan 2002
    Grand Marais,MN
    231
    I think he meant bootdisk.
    Senior Member upinya's Avatar
    Apr 2002
    Austin Tx.
    604
    Yeah.. I think he meant the boot disk. Just put in XP Pro. and install, follow the prompts to delet the current partion, it will ask you something like "Are you sure you want to install XP over the current partion" or something like that. If you say "YES", it will totally reformat you C Drive, and all info on it will be deleted, and XP Pro will be installed on it.
    Australia
    575
    sorry, I ment bootdisk
    all these hitech names, give me a break
    shahani
    Guest
    Check this:
    "Free Utility to Wipe Hard Disks Clean
    Dan Rhoads wrote in about a disk utility that might be able to clean your hard drives. No, not from dirt! I wrote about how difficult it is for software to clean a hard disk of old data. There are a lot of places where "remnant" data can hide, and if you're trying to prevent people from gathering evidence on your computing activity, you certainly don't want those remnants lying around! You have to put this utility's files on a floppy and read the instructions carefully, but it seems to do the job. If you're into cleaning hard disks with a magnet or pulverizer, check out AutoClave to download your own FREE copy and save those disks from a premature death:
    http://www.winxpnews.com/rd/rd.cfm?i...30TI-AutoClave "
    Ultimate Member F/A-18 MechDood's Avatar
    DFW
    1,176
    Extremely simple. Boot from CD-Rom. All the options are then there.
    “MICROSOFT: Where do you want to go today? APPLE: Where do you want to go tomorrow? LINUX: Are you coming or what?”
