Dual Boot help
Currently Active Users: 1960
Discussions: 204,347, Posts: 2,417,510, Members: 249,759
Old August 9th, 2002, 01:26 PM   Digg it!   #1 (permalink)
MrPurple's Avatar
Send a message via AIM to MrPurple
Dual Boot help
Ok, I got my mobo from Soyo back, and I am ready to venture into the wonderfull world of Linux.
Now I need help.
I have Win XP installed on my first drive.
I want to install Linux on the second drive, but how do I go about doing a dual boot.
I really don't want to experiment because I don't want reinstall XP, or try to fix the MBR.
Also how would I go about making it so that at boot it defaults to XP?
Thanks alot for your support.
MrPurple is offline   Reply With Quote
Old August 9th, 2002, 01:56 PM     #2 (permalink)
eweruk's Avatar
Send a message via ICQ to eweruk Send a message via AIM to eweruk
Have not done much dual boots with Linux but I know Linux will setup a LILO boot loader so you will have a GUI screen to choose OS. There are a lot of Linux guys on the forum so they can shed more light on this.
eweruk is offline   Reply With Quote
Old August 9th, 2002, 04:30 PM     #3 (permalink)
S.D.Willie's Avatar
Send a message via AIM to S.D.Willie
refer to this thread if you dont want to install lilo in the MBR and want to use XP's bootloader.
SD
ps. it worked like a charm by the way with redhat, drake, etc
by doing it this way XP will automatically be the default OS b ut you can right click on my computer, go to properties, startup and recovery. in there you can change the default, set timeouts and what not. good luck.
My signature really sucks
S.D.Willie is offline   Reply With Quote
Old August 9th, 2002, 09:31 PM     #4 (permalink)
griobhta's Avatar
Send a message via Yahoo to griobhta
There is an update to that method, you will see it down near the end of the thread but here is a new thread on the topic.
Basicaly mow both grub and lilo will boot a ntfs partition so you can uses these to dual boot.
Griobhta
griobhta is offline   Reply With Quote
Old August 9th, 2002, 10:22 PM     #5 (permalink)
MrPurple's Avatar
Thanks, but I got another problem now.
Since I am using the RAID on my soyo board as additional IDE channels, and both of my optical drives are on those channels, I can't boot from the Linux CDs. I know that they work fine since I installed it on my laptop and it worked fine.
PS. Using RedHat 7.3.
Any ideas?
-=Marcin=-
Old August 10th, 2002, 09:03 PM     #6 (permalink)
griobhta's Avatar
you might then have to see if there is a boot floppy that has the specific drivers for your raid channels. CHeck the red hat web site for different types of boot disks.
Griobhta
Old August 10th, 2002, 09:12 PM     #7 (permalink)
Jeordiewhite's Avatar
Send a message via ICQ to Jeordiewhite Send a message via AIM to Jeordiewhite Send a message via Yahoo to Jeordiewhite
Yes, install the driver's first thing, when you install choose grub over lilo. I have had prob's with lilo, trying to boot anything besides 9x windows. Since I only use windows 2k and XP I find it necsasery to use grub, Since I didn't have option in suse 8.0 to boot from grub I had to get boot magic. Just a little wrong doing in the setup can lead to bad things. So don't over look anything.
(´¸.·*´¯`*»- ->Jeordiewhite
Jeordiewhite is offline   Reply With Quote
Is It Just Me? (1083)
Video Card Dilemma (17)
Happy PI Day! (6)
ACORN Workers Indicted for Voter Fr.. (38)
Hopefully the last thread I make be.. (17)
Computer getting hot! (7)
screen cleaner??? (9)
Computer won't turn on (12)
Internet Censorship. (5)
[ F@H Chat] 03/07/10 New Month New.. (50)
Upgrading Video card (17)
Broken Hard Drive (7)
new case and still a werid buzzing .. (9)
TechIMO Signature Policy Update (39)
Dell Battery repair (8)
Mac parts question (0)
Nvidia 196.21 and refresh rate (0)
Cool website! (0)
Windows 7 - Do you want to change the.. (0)
ipod fault???? (0)
Notepad won't open (2)
iPod Touch 3rd. Gen (0)
ventrillo not working for others (0)
Windows CE stuck on intranet (0)
wanna run setup switch for VGA adapor.. (1)
Looking for drivers for Toshiba lapto.. (3)
WAN settings (0)
RA2 - Multiplayer not Working (2)
RUN:cmd..... (2)
Bad BIOS checksum. Starting BIOS Reco.. (5)
Mouse not responding (1)
External hard drive not working on la.. (5)
school report... (1)
