Page 1 of 2 1 2 LastLast
Results 1 to 20 of 36
    Ultimate Member TOAD6147's Avatar
    5,479
    Need a Win9x memory monitor
    Can anyone recommend a utility for monitoring memory in a Win9x environment? My fawther-in-law's computer has 256 MB's RAM and at idle has only 2% available according to RAMBooster. I need to know what's eating it all so we can disable some of the garbage. I know he has Lotus123 running as well as someother suites but not exactly sure. Any help appreciated.
    5,479
    Bumpity Bump!
    PLEEASEE!!
    Ordained Mommy NeoStarO1's Avatar
    Big Sky Country
    5,765
    Doesn't the task manager show what proccesses are running and the percentage of memory its taking???
    Been a while since used 98 so can't remember for sure if the task manager shows that. I know it does on 2k
    5,479
    I wasn't aware Win9x had TaskManagers.
    foolish their lack of understanding."
    Ambrose Bierce
    Big Sky Country
    5,765
    hmmmm, like I said its been a while since I used 9x OS's but doesn't it show processes running when you do a contol, alt, delete? And aslso show how much mem and cpu processes are being used.
    I guess not, I just spoke to someone, guess in 9x you can only kill processes.
    I used to use maxmem years ago, i allowed you to control the usage and clean out mem to free up mem. Don't think you want that cuz you want to find what is hogging up resources.
    Heres is maxmems site anyways.
    MaxMem
    Description of MaxMem
    Description: Ensure that you always have as much physical memory available as possible with this memory-management utility. Set minimum amounts of memory to be made available under certain circumstances, and this program will passively monitor how system resources are being used. It runs in the system tray and shows exactly how much memory is available, as well as graphs that illustrate how you've been using memory over the last 60 seconds
    I'll keep looking and see what else i can find.
    Aug 2002
    Midwest
    107
    First Run Msconfig.exe in your C:\WINDOWS\SYSTEM folder... I'm guessing that windows is on his C: drive. Go to the startup tab on top and Take a look at what's all running at startup and kill all the unnecessary "junk" that doesn't need to run by unchecking it...Your system will need to reboot afterwards...Then switch your memory manager to : MAXMEM from Analog X(It's a lot better) instead of Ram Booster... here's the link to the download:
    http://www.analogx.com/contents/down...tem/maxmem.htm
    Have a good one!
    Big Sky Country
    5,765
    Hmmmm found something else that might work.
    Called MPower
    http://www.pcworld.com/downloads/fil...d,16880,00.asp
    edit: this one states you can actually see what is hoging up your resources and help free them up.
    Max mem is good too but won't show what cpu usage is either.
    Aug 2002
    Midwest
    107
    Just do what I said in the previous post and you'll be GOLDEN...
    Big Sky Country
    5,765
    Re: Need a Win9x memory monitor
    He already knows how to get rid of garbage, needs a utility to see what is hogging is resources of memory and possibley cpu usage.
    Aug 2002
    Midwest
    107
    That's funny cause all you NEED to know is what Apps are running at startup...You can tell what other Apps are running after startup by writing down on a piece of paper what Apps you opened...geez
    Aug 2002
    Midwest
    107
    If you want to monitor you CPU go to www.tucows.com , go into their windows section, and do a search on: cpu. You'll find a bunch of apps there that will help you on that...
    Big Sky Country
    5,765
    might not be a start up application that eatting up his memory, could be an application that is memory intensive and he won't see which ones they are unless its running and he can see which one is hogging up resources.
    So before going in and disabling startup items, it does help to know which ones are causing the problems.
    Many grapic desgin programs are not in the start up menu but are mem hogs.
    Aug 2002
    Midwest
    107
    Active CPU 1.12 & Win9x/ME Task Manager 1.0.7 are just a couple of them there and they are both Freeware.
    Aug 2002
    Midwest
    107
    They would still show up in MSCONFIG if you would just try it...
  15. #15
    Big Sky Country
    5,765
    Yes you are right they would show up in Msconfig, however it will not show the mem or cpu usage as like i does in 2k and XP. Dunno about ME, never used ME.
  16. #16
    Aug 2002
    Midwest
    107
    ok...then you might want to try Active CPU 1.12 & Win9x/ME Task Manager 1.0.7 from the tucows site...they are both very small apps that should do the trick...
  17. #17
    Aug 2002
    Midwest
    107
    Plus both apps are Rated very Highly... 4 cows and 5 cows respectively...
  18. #18
    Nov 2001
    Belgium
    127
    Hi try Wintop from MS, it can help.
    http://www.microsoft.com/windows95/d.../w95kerneltoy/ (55 Kb).
    Direct download : http://www.microsoft.com/windows/dow...95KRNLTOYS.EXE
    Do no pay attention to the warning about Win98, Wintop is safe to use in any version of Windows.
    Just install it via the wintop.inf file and see what program or process keeps your system busy.
    It shows CPU usage of all programs running, even those which are not visible when you do CTRL+ALT+DEL.
    Pierre.
    Pierre.
  19. #19
    May 2000
    330
    get memturbo it'll monitor and if needed free up memory its needed for the via 133a chipsets bad memory management.EDIT:should also have added that it runs on task bar so you are always able to see how much ram is available.heres the site:http://www.memturbo.com/downloads.htm
  20. #20
    NDC
    NDC is offline
    Xtreme Member
    Jun 2000
    Burbank, CA
    7,880
    Personally, I like RAM Booster which I always used under Windows 9x for monitoring and recovery purpose. I still use it under Windows 2000 and XP just for monitoring. The screen is quite convenient to read ina glance.
    [NDC]
