August 10th, 2002, 02:11 PM #1Junior Member
- Aug 2002
- Location
- Dallas, Texas
- 3
How to stop hidden programs from running?
How do keep all of those programs in the system tray, or that stuff in the right side of the task bar from running, or starting when you boot the system?
I know you can cntl+alt+del each one of them, but there are so many, it takes about 5 minutes. All of these programs running in the "back ground" seem to slow up my computer. I want most of them GONE! Please help, Thanks.
Also it seems my computer is so cluttered that scan disk, or defrag won't run to completion. They seem to get hung up and become non responsive. What's the best way to clean up a hard drive, or would Win XP solve this?
I'm using: Win ME, and I just installed a new GIGABYTE MB, and 1.7mhz 478 celeron, 20gig maxdor HD.
August 10th, 2002, 02:23 PM #2
Most programs that don't start because they are in the Startup folder on the Start Menu can be stopped from loading by using the "msconfig" utility
Start>Run>msconfig>Startup tab
August 10th, 2002, 02:54 PM #3Senior Member
- Oct 2001
- 959
welcome to techimo (usually someone beats me to this
I agree with Fingers about the msconfig tip, but I'd go one further
when you say slowing down you machine, what exactly do you mean? boot, apps, general system browsing?
t/j
August 10th, 2002, 08:14 PM #4Junior Member
- Aug 2002
- Location
- Dallas, Texas
- 3
My computer just seems sluggish, and some programs won't open. When I right click on the icon, My Computer, go to properties, then performance, my system resources is below 60%. After I close all the programs using ctrl+alt+del, my system resources are at 86%. I just want to know how to control the System Tray, and how to really clean up my hard drive.
August 11th, 2002, 12:50 AM #5Member
- Aug 2002
- Location
- Midwest
- 107
Definately Use Msconfig and kill all the unneeded apps!
August 11th, 2002, 01:05 AM #6Junior Member
- Aug 2002
- Location
- Dallas, Texas
- 3
YES! I found all those files in the startup folder. Thanks ya'll, never knew about this msconfig file. Thanks!
August 11th, 2002, 11:28 PM #7
I like this little utility called "startup cop." It's very handy as it stops things in msconfig and the start menu from coming up, but they can be removed completely or disabled. Plus you can set different profiles. For instance you can practially run your own "safe mode" by loading a profile where absolutely nothing starts up and rebooting. Plus, it doesn't stay resident in memory, only when you're adjusting settings.
http://www2.sunysuffolk.edu/mandias/...artup_cop.html
Sam
Through teaching them about life his way, Aidan gradually discovers some of the parts of himself he couldn't find." Watch The Hangover Part 3 Online Supported by the City of New York and Henson's...
Engagement Brie especially
