Results 1 to 8 of 8
    Sep 2002
    10
    PLEASE I NEED HELP WITH KAZAA
    This started happening recently ish - last 2 weeks or so, but nowadays when i am trying to download something from Kazaa, most of the time I get a "Failed" status after a few mins, and then, when I try to resume the download, it starts from the very begining again. I know I have more than enough space on my hard disk, so anyone know what the problem is?
    Member JKLiMpKoRn's Avatar
    Jul 2002
    NJ
    287
    ditch kazaa and get kazaa lite (www.kazaalite.com) Kazaa lite has something nice to it... it comes with a program called "Speed up" that automatically finds more sorces for what your dling. to tell you the truth i have no idea whats wrong with your kazaa ... whats your OS, RAM, Internet speed (just saving the tech support guys time... they always ask these questions )
    Sep 2002
    10
    Ok, yeah, I am using Kazaalite.
    Lets see, I am running Win XP Pro, 384 MB ram, and using ADSL on Verizon.
    Anyone got any ideas?
    CRAP! Brainchild's Avatar
    Monett Missouri
    4,341
    are you running the newest, latest greatest...err.. so to speak KaZaALite?? There is an upgrade availible. 2.0 I think, well anyway, I'm still running the 1.72 without problems, although sometimes I have to restart the APP to get it to connect, even though it says it's connected
    Have you ran something like Ad-Aware, or other spyware removers?? If you erase the dummy dll file in ad-aware, it wipes out the resume feature,
    Hope This Helps
    BC
    Check out my band Saving Silence
    Member Marshall Law's Avatar
    Jun 2002
    Bellevue, NE
    97
    If you're not running the 2.0 version of either KaZaa (or better yet, KaZaalite) it probably won't work. I had a similar problem, and the latest version fixed the problem.
    Sep 2002
    10
    I'm using Kazaalite 1.72 as well. I just recently downloaded it, switched over from Kazaa (as Kazaa was having the same problem), and haven't run adcache since the installation of Kazaalite. So, I'm pretty sure I haven't deleted the dummy dll file.
    Monett Missouri
    4,341
    I just found this when I went to KaZaalite.
    Attached Thumbnails Attached Thumbnails PLEASE I NEED HELP WITH KAZAA-kl.jpg
    Sep 2002
    10
    I tried downloading the new Kazza v2, problem is, when I tried to install it, at setup, it just stays at 0%...doesn't change, don't know what is wrong with that either.
