Sound Recorder
Currently Active Users: 2671
Discussions: 200,520, Posts: 2,374,496, Members: 245,842
Old November 7th, 2002, 08:27 PM   Digg it!   #1 (permalink)
alondra's Avatar
Sound Recorder
just read that it is posible to record from a mike msgs to save for Email. with sound recorder. hooked up mike. but does not seem to record. no waves on the strait line, what am I missing
Thank God I'm a country boy-John Denver
Thank God for a backup comp. Alondra
alondra is offline   Reply With Quote
Old November 7th, 2002, 08:30 PM     #2 (permalink)
JohnE.'s Avatar
Send a message via ICQ to JohnE.
Operating system is? Soundcard is?
Need more info to recommend possible solutions.
JohnE.
JohnE. is offline   Reply With Quote
Old November 7th, 2002, 08:35 PM     #3 (permalink)
maface's Avatar
This might helpMic its for windows 95-98 but same idea for win 2000 and XP
maface is offline   Reply With Quote
Old November 7th, 2002, 08:36 PM     #4 (permalink)
alondra's Avatar
using win98, with soyo on board sound. in one comp and SB live in the other.
Old November 7th, 2002, 08:44 PM     #5 (permalink)
caddmannq's Avatar
You got mic mute turned on?
Beware the Penguinator!
caddmannq is offline   Reply With Quote
Old November 7th, 2002, 08:57 PM     #6 (permalink)
willy_ph's Avatar
Is the mic in channel muted in the mixer thingy.
The difficulty is to try and teach the multitude that something can be true and untrue at the same time. -- Arthur Schopenhauer
willy_ph is offline   Reply With Quote
Old November 7th, 2002, 09:29 PM     #7 (permalink)
JohnE.'s Avatar
A few items to check:
Open Control Panel>Multimedia and click the big button under "Playback". If you see a channel/volume slider for Microphone make sure it isn't muted, set the volume around 75% then click Advanced and make sure "Microphone +20 dB Boost" is selected. If you don't see the Advanced button on the microphone channel go to Options and make sure "Advanced Controls" is enabled.
If you don't see a channel/volume slider for Microphone you'll need to go to Options>Properties>Adjust volume for playback - make sure Microphone is checked under "Show the following volume controls"
That should take care of the input... now the output:
Control Panel>Multimedia, click the big button under "Record". Use the similar steps from "Playback" options to make sure you have a Microphone channel and set it up the same way you did for Playback (advanced controls, +20 dB boost, etc) and under Recording Control select Microphone (not Line-in, etc). Also, make sure your mic is plugged into the microphone input and not the Line-in.
While you're there in Mutimedia, select "Use only preferred devices" and "Show volume control on the taskbar". This'll give you quick access to options if you need to check/tweak them again.
Give that a try and lemme know if it worked for Sound Recorder
JohnE.
Old November 8th, 2002, 02:58 PM     #8 (permalink)
alondra's Avatar
tried all these things, can hear mike in earphones, can play sounds from stored stuff, and the waves show , but will not record from mike. verry strange.
Old November 8th, 2002, 03:30 PM     #9 (permalink)
OH NO!
Brainchild's Avatar
Send a message via Yahoo to Brainchild
double click the speaker icon in the tray, upper lefthand corner of the mixer, choose options>properties. this will bring a box up, should have two radio buttons in it, choose record, this will bring up the record mixer. Adjust the mic from there and see if it helps
Sometimes it works sometimes it don't
*shrugges*
BC
BTWid ya check the properties of the sound recorder to make sure it's got the soundcard and such set right?
Brainchild is offline   Reply With Quote
Old November 8th, 2002, 03:33 PM     #10 (permalink)
caddmannq's Avatar
Ummm..the record mixer is where the mic mute button is, right?
Is It Just Me? (1660)
HELP!!! What do you think of this s.. (25)
windows 7 retail and rtm (5)
Review My Build (6)
My 1st pc build (40)
Aero in Vista (7)
[F@H SPAM 11/1/09]New month . . . n.. (34)
slaving laptop drive (7)
[F@H SPAM 11/08/09] Where has all the.. (1)
nvidia geforce 9500GT 1gig DDR2 (3)
[F@H SPAM 11/1/09]New month . . . new.. (34)
Endless BSOD to Recovery Manager loop.. (0)
HELP!!! What do you think of this sys.. (25)
New Processor, Monitor will not turn .. (3)
Determining ip route and serial addre.. (8)
can u beat freecell # 1941? (11)
Dell 8300 Graphics Problems (1)
Powe Director v8 (0)
Review My Build (6)
2009 Build (4)
