Images won't load on Opera
Currently Active Users: 1862
Discussions: 200,899, Posts: 2,378,815, Members: 246,268
Old November 26th, 2002, 12:21 AM   Digg it!   #1 (permalink)
Location: City with no good sports teams: Bulls, Bears, Sox, Cubs...etc.
Send a message via AIM to Xster
the title is self-explanatory. I'm running Opera 6.05 registered under winXP. My firewall is ZoneAlarm 3.1.395. Even the smilies that i can add aren't loading on this page...unless i right click and do "reload image". So very annoying...anybody have suggestions?
Xster is offline   Reply With Quote
Old November 26th, 2002, 12:23 AM     #2 (permalink)
Not Really a Member
clear your cache, it could be getting corrupted.
C:\Program Files\Opera\Cache4 ... just whack everything in the directory, it will regenerate it (dont whack the news folder if it exists inthere)
vass0922 is online now   Reply With Quote
Old November 26th, 2002, 12:23 AM     #3 (permalink)
Mean Moderator
EvilRick's Avatar
What does it say under your 'Multimedia' settings under 'Prefrences'?
Make sure "Show Images" is checked.
EvilRick is offline   Reply With Quote
Old November 26th, 2002, 12:29 AM     #4 (permalink)
crouse's Avatar
Send a message via ICQ to crouse
Hit the "g" key for "graphics" it should cycle throught the modes.... no graphics/grpahics/etc
USA Linux Users Group
OpenSUSE.us
crouse is offline   Reply With Quote
Old November 26th, 2002, 06:53 PM     #5 (permalink)
nothing worked, anybody else wanna give it a go?
Old November 26th, 2002, 07:10 PM     #6 (permalink)
Where's the beef?
Scott Tiger's Avatar
Have you tried Opera logged in as a different user? If it works logged in as someone else then you've just got a setting problem. You'll have to uninstall it and then remove whatever Opera installed to your profile and then reinstall it.
If it doesn't work after you log in as someone else then you probably better uninstall and reinstall it. Hopefully that will fix it.
Regards..
Scott Tiger is offline   Reply With Quote
Old November 26th, 2002, 07:10 PM     #7 (permalink)
Night's Avatar
go into the actual opera file its self and find cache then delete all but the news folder.
Night is offline   Reply With Quote
Old November 27th, 2002, 12:10 AM     #8 (permalink)
ok, if i uninstall Opera and reinstall it how do i keep my favorites or transfer them to IE or something? I need my favorites intact, and would've uninstalled it earlier but didn't know how, thx. And i DID actually go into the folder and delete the files but it still doesn't work.
Old November 27th, 2002, 12:14 AM     #9 (permalink)
Uncommon Man
samwichse's Avatar
There's a file in the opera directory called "opera6.adr" or "opera5.adr"
Just copy that elsewhere, as it has all your bookmarks. After you reinstall, just copy it back to the opera directory (overwriting the default install one) and poof, they're back
samwichse is offline   Reply With Quote
Old November 27th, 2002, 12:23 AM     #10 (permalink)
Not Really a Member
or if it makes you feel better you can go into File --> Export --> Bookmarks
Is It Just Me? (2783)
Foreign voltage (5)
A good PSU? (9)
California Passes Anti-Flat-HDTV Le.. (38)
Fox uses old news clips to inflate .. (33)
Print spooler problem (5)
HIS HD5770 graphic card question (8)
EVGA 9800 gtx help with finding a g.. (5)
Mysterious Boot manager (9)
Ideal cheap graph card for PC-Gamin.. (12)
New Build the Montior is blank (8)
Is the PSU I received dead? (3)
Install XP pro and a Vista laptop ?? (1)
Foreign voltage (5)
hybernate option (2)
A good PSU? (9)
blender help (2)
Hard drive freezes boot (1)
System recovery disk maker (2)
Like New Wacom 12x19 Intuos 3 + Grip .. (1)
windows 7 internet problem (3)
EVGA 9800 gtx help with finding a goo.. (5)
Skillsoft Network+ Study Software Que.. (8)
Ideal cheap graph card for PC-Gaming? (12)
Internet very slow since updating AVG.. (13)
