Thread: Please help
January 5th, 2003, 03:31 AM #1
Please help
I am trying to update from windows 98 to windows xp pro and I am having problem getting computer to load after install. I have had to reload 98 to use my computer. I have a hp pavilion 8496 it meets a requirements. it is 501mghz, PIII, 384memory. I was hoping someone could help me to get it to work on this system or let me know if it is a waste of time.
Thanks in advance for any help that anyone can give.
January 5th, 2003, 03:38 AM #2
It should work. Are you receiving an error during install? Will it not boot after installing XP? Are you doing a clean install or XP or trying to upgrade?
And Welcome To TechIMO
January 5th, 2003, 03:38 AM #3
http://h20015.www2.hp.com/en/documen...ion10396&lc=en
There is a link for thier info on XP
http://h20015.www2.hp.com/en/softwar...396&sw_lang=en
Taken from there. it might be a bios issue. They state they are not updating to ensure XP compatibility. Post back the exact err. and we might be able to help.Last edited by Wizzard~Of~Ozz; January 5th, 2003 at 03:40 AM.
January 5th, 2003, 03:54 AM #4
I don't rember exactly what it said. I did have some problems getting the disk to load xp in the first place. Then finnally it completed and after I shut down the system my problem started and it would not load again.
Thanks krohnjw glad to be aboard..
January 5th, 2003, 03:57 AM #5
forgot I tried both ways and still had same problem,both update and clean install.
January 5th, 2003, 04:00 AM #6
Does the install complete? When you boot XP (Assuming the install completes) do you receive a bluescreen?
January 5th, 2003, 04:07 AM #7
yes and then it goes to last known good boot or something like that.
is there a long line of sniper serial murderers who are not currently served well by current 10 to 20 power scopes? Are there alot of bad shot serial killers just waiting for this technology???
The perfect gift for an aspiring...
