Results 1 to 7 of 7
    Bloomingdale IL
    1,669
    Need a little bit of Linux help.
    My goal is to get my printer on a remote machine working on Linux and getting the linux machine to see the win98 machine.
    Info on the printer.
    IP is 10.0.0.1
    \\john peters\hp
    Ultimate Member pbharris's Avatar
    Chicago, IL
    2,514
    hello,
    try printtool and set it up as a smb printer.
    to see the remote machine you need to have samba client installed.
    Odds are very good there are several spelling mistakes in this post.
    Bloomingdale IL
    1,669
    I installed the printer using that program. Now how do i find out if it is working?
    Chicago, IL
    2,514
    can you use the 'print test page' function in print tool? also just a lp filename.txt should work.
    Bloomingdale IL
    1,669
    I says that there was an error while priting this page.
    Chicago, IL
    2,514
    humsss....
    lemms check.
    Chicago, IL
    2,514
    hello,
    unforuntunaly i can't give an easy answer - yet. i am look at stuff here as time permits.
    http://www.linuxprinting.org/howto/n...ORK-TO-WINDOWS
