Results 1 to 15 of 15
    Ultimate Member jmebonner's Avatar
    Feb 2003
    MinnesOta
    1,714
    does system restore restore files, like viruses I've removed?
    Hi All,
    My computer is all squirrely this morning, I'm lucky to be typing this! I ran Norton AV scan last night and it picked up 15 viruses, all that stupid WP32.Handy.DLL or something from Kazaa, I don't know why my auto protect isn't catching it.
    Anyway, I deleted all of the infected, and when I tried my connection this morning (1.5 MB cable) it's off and on. I calles tech support and we released, and renewed the ip address and all that, to no avail, it keeps telling be a network cable is unplugged in the task tray (It is NOT). Soooo, If I restore to say, Saturday, the viruses will still all be gone, right?
    Wow, that was a lot of typing for a simple little question!
    Senior Member tmx468's Avatar
    Nov 2002
    Surrey, England
    837
    The restore CD works by starting your PC from scratch, and restoring it with software loaded as it looked when it first arrived from the manufacturer. As a result, anything installed after you got the PC will be lost, as will all your personal files. So make sure they are backed up first, or you will lose all personal data!
    Ultimate Member EvilRick's Avatar
    N of Music City, USA
    7,832
    I think it all depends on how much 'System Restore' space you've allocated. If the files were there when the restore point was set, then yes, they'll be there when you restore from that point.
    You could look here for more info.
    Are you using an ME or XP?
    Feb 2003
    MinnesOta
    1,714
    I'm using XP pro, and I'm meaning the system restore function in the system tools menu, not the restore cd. Sorry, should have made that clear
    Nov 2002
    Surrey, England
    837
    System restore would not necessarily filter out the bad that has already occured on the system - it could work, it might not.
    Mar 2002
    Under Your Bed
    8,909
    Nice link ER...I was about to provide some info, but that M$ link pretty much covers what I was going to say about the restore points.
    Feb 2002
    Mauldin, SC
    1,383
    Hey, Mike:
    Is it safe to say that System Restore is basically a glorified, user friendly,(when it works), "registry restore" function? Or is that an oversimplication? (I've just always thought of it as such).
    Haven't looked at Rick's link yet, but will do so. . .
    - Bill
    7,832
    I don't know about Martoch, but I don't trust it. That's one of the first things I disable when I setup a PC.
    Feb 2002
    Mauldin, SC
    1,383
    Myself, as well, Rick:
    Sometimes I'll remember to enable System Restore before installing new apps, etc., just in case. But it does take up disk space and, like anything running in the background, tends to slow your system down, and use up system resources.
    - Bill
    Feb 2003
    MinnesOta
    1,714
    ER, What do you mean by 'not trusting it' ?
    7,832
    I wouldn't rely on it to protect your system in case something went bad is all I mean.
    I think most would agree, it might work and then again, it might not. I'm not willing to chance it. It might even make things worse. If it gets bad enough that I can't fix it w/ 'Recovery Console', then I start from scratch.
    Just remember . . .
    BACKUP, BACKUP, BACKUP!
    Feb 2003
    MinnesOta
    1,714
    good point, I think I'll just backup everything and start over, thanks for all your help everyone.
    jme
    Mar 2002
    Under Your Bed
    8,909
    Sorry for the late reply, to be honest I don't use it either...I tried it once just for the heck of it...it didn't work for me at all. As you guys already mentioned, I back up everything as I install it (if it's important enough to me). Sure, the "restore" function is a nicety, but I don't find it necessary at all.
    Partitioning hard drive space and a CD-RW take care of everything I need to keep safe.
    zen
    zen is offline
    Ultimate Member zen's Avatar
    Jan 2002
    Pennsylvania
    3,656
    Originally posted by bill1971
    Hey, Mike:
    - Bill
    Im not mike but, yes you are correct.
  15. #15
    Dec 2001
    NY
    4,519
    i might be a little late here but the system restore might fix the problem with the corrupted NIC settings. since the system backup/restore only 'protects' the registry & key system files, it would have nothing to do for the infected files, unless they were part of the forementioned group.
