xp home reinstal
Currently Active Users: 1476
Discussions: 200,956, Posts: 2,379,485, Members: 246,317
Old February 26th, 2003, 11:45 AM   Digg it!   #1 (permalink)
waynezo's Avatar
Question
xp home reinstal
Do I have to reformat my harddrive to reinstal xp home.
My OS was installed by CYBERPOWERPC and came with a recovery cd. Can I use the cd to boot up the system if it won't boot from the harddrive? Also I've been running regcleaner and have defraged my drives(raid array striped 0) Are there any other maintenance tasks I should be doing to keep system running good? The reason I ask is last week my system became unstable and would only boot after several attempts.
waynezo is offline   Reply With Quote
Old February 26th, 2003, 11:52 AM     #2 (permalink)
rpertusio's Avatar
Send a message via AIM to rpertusio
I'm assuming the Recovery CD will automatically format your drive.
If you had a retail XP CD, you could try the following:
How to Repair Windows XP by Installing Over top of Existing Setup
Maybe the CyberpowerPC CD is similar? If it is a full blown recovery CD, it may not even give you the option to repair, and will automatically format. Be cautious!
(If anyone else knows first hand about CyberpowerPC recovery CD, please add your comments)
- rp
rpertusio is offline   Reply With Quote
Old February 26th, 2003, 11:54 AM     #3 (permalink)
Mean Moderator
EvilRick's Avatar
You don't HAVE to format, but I'd recommend it.
The Revocery CD should have all the XP Home files on it. You'll just have to do a little hunting to find them. If you boot w/ the CD, does it give you an option to just install the OS w/o any extra stuff?
EvilRick is offline   Reply With Quote
Old March 1st, 2003, 04:29 PM     #4 (permalink)
Usually recovery CDs reformat and sometimes repartition, before they restore the operating system and programs (some don't restore programs.) I have seen a few that give a list of options, but this is rare. Everyone "I" have seen warns that it is about to format the drive, and that all data will be lost, before it proceeds.
HaroldW is offline   Reply With Quote
Old March 1st, 2003, 04:36 PM     #5 (permalink)
I just noticed you are running RAID-0. Some recovery CD's will only work with the original hardware that came with the system. If you are running software RAID, I suspect there will be a problem (running the recovery CD the way it's meant to be used.) If you are running hardware RAID there is less chance of a problem due to the RAID configuration.
Is It Just Me? (2943)
Print spooler problem (15)
Some methods to retrieve lost Windows.. (0)
lost Windows user name and password (13)
whats the fastest dvd ripper? (13)
How to Convert Blu Ray Disc Movie to .. (0)
Virus advise (8)
Internet Lost (3)
How to convert MP3's (4)
