Grub Help!
Currently Active Users: 2310
Discussions: 207,853, Posts: 2,459,457, Members: 253,353
Old April 6th, 2003, 12:17 AM   Digg it!   #1 (permalink)
munky's Avatar
Send a message via ICQ to munky Send a message via AIM to munky
Exclamation
Grub Help!
I got a new comp (by new a p2 400mhz..its free shutup!) I have 2 drives in my server. A 15 which holds everything and a 40 which i had another os for a while. The 40 gig has the boot record right now. The master (hda1 which is the 15) has grub ready, I just need to get it as the mbr b/c I wanna remove the 40 and use it on the new comp. MY root parition is hda3, my boot partition is hda1. What should I do?
munky is offline   Reply With Quote
Old April 6th, 2003, 12:39 AM     #2 (permalink)
Uncommon Man
samwichse's Avatar
What shouldn't ouy doo?
samwichse is offline   Reply With Quote
Old April 6th, 2003, 12:42 AM     #3 (permalink)
munky's Avatar
Well, right now the boot record is on the 2nd drive. IF I take it out, I get a "grub error". I want the first drive to run w/o the second!
Old April 6th, 2003, 01:51 AM     #4 (permalink)
so the 40 gig (to be removed) is your /dev/hda or in grub-speak (hd0) and the boot is on (hd0,0)
from a CLI you need to re-run the grub set-up
grub
root (hd1,0)
setup (hd1)
quit
(hd1,0) being the first partition on the second drive (/dev/hdb1)
however, this is all going to change when you whip out the 40g drive, because then you technically only have a /dev/hda
what I would do is back up the boot config from the 40g as well as fstab for reference
next pull the 40g drive
use a linux install disc to get to a chrooted prompt
reconfigure grub and fstab based on your new hardware config i.e.
grub
root (hd0,0)
setup (hd0)
quit
make sure the 15G has a /boot and stick your kernel and grub.conf in there - make sure the grub.conf is pointing at the right (hd) and you should be good
HTH
the jester is offline   Reply With Quote
Old April 6th, 2003, 08:58 AM     #5 (permalink)
nukes's Avatar
Send a message via AIM to nukes Send a message via Yahoo to nukes
If you're boot partition (where GRUB is installed) is on the second drive, you need to move it to the first as the MBR can only really serve to bootstrap the system and point it to the partition where stage 2 is installed as it only consists of like 512 bytes or so. If you remove that drive, it won't work as half of grub is missing (including your config file)
It is possible to set grub up to run off a FAT partition (if thats whats on your first drive) If you really want something where it can run without the second drive, why not try XOSL (if you have a FAT/FAT32 partition on the first drive that is)
www.xosl.org
_____
NuKeS
nukes is offline   Reply With Quote
Old April 6th, 2003, 09:07 AM     #6 (permalink)
I see that my Saturday night severely impaired my ability to give good advice
Old April 6th, 2003, 10:02 AM     #7 (permalink)
nukes's Avatar
Wait. I think I got it mixed up. Is the 15 the master at the moment and the 40 the slave or on the other channel?
If that's the case, jester's advice will do it.
Old April 6th, 2003, 10:22 AM     #8 (permalink)
munky's Avatar
the 15 is the master, and btw i installed the 15 first with gentoo and then i installed the 40 with clark connect. The 15 still has its grub.conf. So...btw jester your respons confused me
Old April 6th, 2003, 10:46 AM     #9 (permalink)
my apologies
what I would do is
1. get a gentoo install disc
2. boot the install disc and follow the gentoo instructions aside from partitioning all the way up to getting to a chroot shell
3. skip to the grub configuration instructions
4. set up grub on your 15G
5. edit your grub.conf (not forgetting the symlink to menu.lst)
6. remove references to the 40G drive from /etc/fstab
and pull the 40G before you do step 1
Old April 6th, 2003, 07:12 PM     #10 (permalink)
btw, you don't need to chroot to install the grub mbr, you can do it straight from the gentoo cd just after it's finished booting.
KraM is offline   Reply With Quote
Ask a Tech Question (free)!
Is It Just Me? (1014)
Intel Core i7 920 heat issue help p.. (19)
Woman Convicted of Drug Fraud Joins.. (5)
I need help building a computer. 40.. (33)
Best gaming GPU for $200 or less? (17)
Nvidia GeForce gt 220 problems (21)
Trouble connecting to Apartment Int.. (16)
net use command (13)
cant find drivers (8)
Wireless coverage over 3 hotel floo.. (17)
Laptop Battery issue? (10)
Zombie Cookies Privacy Lawsuit Targ.. (6)
Rate My First Computer Build (8)
new video card- screen changes to c.. (8)
Trouble connecting to Apartment Inter.. (16)
Wireless coverage over 3 hotel floors (17)
Can't open zip files in vista??? (16)
Server 2008 "read only" (0)
120G External Drive, USB 2.0: Works o.. (2)
Help Dell Latitude D610 Power Problem.. (6)
Intel Core i7 920 heat issue help ple.. (19)
new woot (5)
Which Graphic is better? (1)
On startup my monitor clicks forever .. (1)
Cavalier Internet (12)
PC turns on, gets normal post beep bu.. (0)
D drive failure? (3)
In need of Help! (1)
DVD Recorder Set-Up (3)
System fans not working (2)
good video card around 100-200 dollar.. (3)
Linux had disk space full (3)
Minidump Help (1)
I need help building a computer. 400-.. (33)
Redirect malware won't go away (6)
laptop keys broken!!1 (3)
TechIMO Copyright 2010 All Enthusiast, Inc.
