Results 1 to 4 of 4
    Member NDuser's Avatar
    Devils Lake, ND
    160
    Question I need help backing up mail & favorites
    I just installed Win ME and now I need help backing up the mail, addresses, and Internet Favorites so that I can restore them into the new OS.....Can this be done easily?
    NOVA
    33,798
    46
    to save the favorites just simply look for the folder with the blue star called favorites
    To save email address open outlook and click file and then export. save your address backup to a azip disk or another drive
    than to put back in the email address just simply click file import and choose the file you created.
    check this site
    simple
    JaYsin
    Ultimate Member RayH's Avatar
    San Francisco, CA
    2,800
    You can use Copy and Paste to back and transfer your Favorites.
    With your Address Book, assuming you mean the standard Windows OE address book, save it by EXPORT > Other Address Book> Text (Comma Seperated Values). It'll get saved as an Excel spreadsheet. When the option appears, be sure to check all the appropriate boxes to save, like nicknames.
    To transfer, IMPORT ..........
    If you want the OE e-mail, look for a freeware called DbXtract!
    Ultimate Member wyvrn's Avatar
    2,384
    If using outlook, you can also create a personal folder (.pst file) and save your mail there, burn it to cd or whatever.
    Tools | Services, click Add and personal folder.
