How do I make my mouse single click...
Currently Active Users: 1502
Discussions: 200,954, Posts: 2,379,482, Members: 246,316
Old April 15th, 2003, 01:04 AM   Digg it!   #1 (permalink)
My list of Windows XP questions
How do I make my mouse single click and open items in Windows XP?
Also is there a way to make the quick launch toolbar longer? In other words I want it to show more than 3 items.
d1sc g0lf3r is offline   Reply With Quote
Old April 15th, 2003, 01:19 AM     #2 (permalink)
Original HDSP's Avatar
Open Control Panel and click on "Appearance and Themes". Then go to "Folder Options" and on the first tab (General), the last group titled "Click items as follows", select the first option.
To make the quick launch task bar display more than three items, right click on it and uncheck "Lock the Taskbar".
Doug
Original HDSP is offline   Reply With Quote
Old April 15th, 2003, 01:44 AM     #3 (permalink)
Thanks for the fast reply
Does Windows XP disable Java in IE by default? and if so how do I re-enable it?
Old April 15th, 2003, 09:35 AM     #4 (permalink)
I think I figured it out. I installed Sun's J2SE 1.4.1 and that seemed to fix my problem. I am guessing they removed Java from IE in Windows XP?
Old April 15th, 2003, 09:55 AM     #5 (permalink)
Retired mostly.
MS Java VM was removed from xp at request of sun, you can get suns vm from their site - as you already did.
-M
Is It Just Me? (2943)
Print spooler problem (15)
whats the fastest dvd ripper? (13)
How to Convert Blu Ray Disc Movie to .. (0)
Virus advise (8)
Internet Lost (3)
How to convert MP3's (4)
Asus P4G8X Mobo (6)
