Join TechIMO for Free!
Topic: Have any of you wondered why (on WindowsXP----and presumably on other WindowsNT machines as well(wasn't able to check, as I don't use them)) you cannot access the System Volume Information directory? I have, and I find ...
Thread Tools
Currently Active Users: 2247
Discussions: 186,224, Posts: 2,222,765, Members: 229,783
Old April 22nd, 2003, 05:40 AM   Digg it!   #1 (permalink)
Answer to "System Volume Information access denied" question, and also system restore
I have, and I find it extremely annoying that files on your own computer are hidden from you! (I'm the curious type)
So,...if you absolutely must know, YES the restore points ARE stored right inside this special directory
While attrib will let you know of the existence of this directory, you still do not have access. However, that is all about to change
Suppose you have named your user account "Bob"
Well, pull out that trusty command prompt box, "cd" on over to your root directory, and listen up
enter the following command while having sufficient permissions (being the only user of a machine or logging in as administrator should be sufficient)
cacls "System Volume Information" /E /P Bob:F
That should all be on one line, BTW Then press Enter.
Now Bob can access all of that stuff!
to change it back the way it was before, enter the following on a line by itself, and press Enter
cacls "System Volume Information" /E /R Bob
Be really careful to include the /E ESPECIALLY, as if you don't, you might just end up with a file for which nothing has permissions to access (and that is REALLY bad considering this isn't just any file but is a very important system directory with backup volume information inside!)
Well,....haven't seen anyone ask this here....but if anyone was wondering...there you go
I still find it extremely annoying to have to do that, though. (also find it extremely annoying how Microsoft hasn't publicly released the NTFS filesystem format specifications)
Maybe this will help the more curious of you
Jüš† ä €öm¶ù†Ê® §ÇÌÈñŒ mÅjÒ®
Jüš† ä gü¥ is offline   Reply With Quote
Old April 22nd, 2003, 04:12 PM     #2 (permalink)
can also change the NTFS permissions from the GUI
right click the folder, and go over to the 'Security' Tab ... may have to take ownership of it, but thats easy enough if you're the admin.
vass0922 is online now   Reply With Quote
Old May 25th, 2003, 01:49 PM     #3 (permalink)
Big
worked Gr8
thanks for the play by play on this "just a guy"
Helped me out a bunch.
Big is offline   Reply With Quote
Old May 25th, 2003, 08:04 PM     #4 (permalink)
darrelld's Avatar
Send a message via MSN to darrelld
Umm, maybe it's just me, but I've never had any trouble accessing that folder. In fact I regularly delete restore points from it.
Will work for food!
darrelld is offline   Reply With Quote
Old June 22nd, 2008, 12:53 AM     #5 (permalink)
Great!
I had a virus in the System Volume Information folder and counld't get a it. I found a bunch of other sites saying "here's how to do this..." and yours was the only answer that actually worked!
Thank you 100X
MS
chillyham is offline   Reply With Quote
Old June 22nd, 2008, 01:57 AM     #6 (permalink)
ATI 4850 FTW!
#43 fan's Avatar
Thank you 100X
MS
Glad an older post helped.
http://www.ubuntu.com
Old July 16th, 2008, 09:56 AM     #7 (permalink)
Smile
Wat a great BRAIN man!!
Hey... This is the best of the best solution for this really hectic kind of problem...
Just wanna say tonnes of thanks to this member...
Keep this up GUY!!
Cheers!!
Harshal
harshgw2k3 is offline   Reply With Quote
Old October 5th, 2008, 08:11 AM     #8 (permalink)
not working ... :(
hi i'm doing all this and it still isnt working .. in dos each time i type it in it just brings up the set of commands (like what to chose from) but still not giving me access to the file :/
can you help?
pauljmic is offline   Reply With Quote
Old October 5th, 2008, 09:10 AM     #9 (permalink)
Steve R Jones's Avatar
Paul can you be a lot more specific?
What are you wanting to do and what are you typing to do it?
Steve R Jones is offline   Reply With Quote
Old October 5th, 2008, 02:51 PM     #10 (permalink)
sorry lol .. i was in a bit of a rush before.. ok so ..
i did an avg scan and i told me i have a virus in the system volume information file .. avg won't delete the virus and so i tried the method here.
i typed in cacls "system volume information" /E/P Paul:F
when i pressed enter t gives me the access control list with basically all the diferent commands .. and yet nothing works.
i tried using G (grant) instead of P and it does exactly the same thing
i am trying to get into the file to delete the infected files
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Is It Just Me? (16968)
hi (7)
So GLAD winter's finally here !! (21)
FolderChat: Weekend time again! (284)
Folderchat Weekday thread (373)
Super folding (18)
Popular Online Pc Retailers (12)
AM2+/AM3 (9)
PSU recommendation, think mines is .. (14)
How to position dos window (0)
Super folding (18)
RETTEN.EXE missing (1)
HDMI Cables (6)
Is it worth the upgrade? (2)
Need advice from you experts... (2)
Help me to find Equivalent Powe.. (156)
Calculating KVA/MAX (7)
Why do you use "Vista".. (29)
Seald copy of windows 95 for sa.. (0)
Various items for sale (1)
Woot-off (5)
