win98 shutdown problem
Currently Active Users: 2879
Discussions: 200,968, Posts: 2,379,687, Members: 246,333
Old May 6th, 2003, 12:39 AM   Digg it!   #1 (permalink)
brunix's Avatar
Question
My wife’s PC runs win98se and just the other day started rebooting instead of shutting down. I haven't tried anything yet to fix it just hit the power button before it reboots. Plan to run SFC, but don't know of anything else to do.
Suggestions appreciated
Brunix
brunix is offline   Reply With Quote
Old May 6th, 2003, 10:21 AM     #2 (permalink)
kjg
kjg's Avatar
I had a similar problem with my comp and it turned out to be caused by some options in the bios. These were the 'Ring on ....' and there were several of them but I cant remember exactly what they were at the moment but I will find out. When I disabled them the comp shutdown perfectly.
Nods as good as a wink to a blind bat.
kjg is offline   Reply With Quote
Old May 6th, 2003, 10:27 AM     #3 (permalink)
Agent_Embryo's Avatar
Send a message via ICQ to Agent_Embryo
Wake on LAN
Wake on Modem
Wake on Ring(?)
Basically turn off all those Wake On... settings unless you really need them.
There have been many issues with Win 98 not shutting down right in the past. I suggest you check out Microsofts homepage for details.
Good Luck!
/AE
This is The Signature©
www.ghostnail.com - my band.
Agent_Embryo is offline   Reply With Quote
Old May 6th, 2003, 10:40 AM     #4 (permalink)
korgul's Avatar
There are 2 patches that MS had for shutdown problems in Win98se. I will see if I can find the Q articles.
Try this link
Win98 issues
korgul is offline   Reply With Quote
Old May 11th, 2003, 03:26 PM     #5 (permalink)
brunix's Avatar
Thanks for the help
The MB is a shuttle 591 and does not have any wake options. I ran SFC and found quite a few missing or corrupt *. DLL’s but that did not fix the problem. I ran the win98se shutdown supplement and that did not fix the problem. In reading some of the links I reached through korgul's link I found it may be caused by a prog not shutting down properly. I try to keep the progs that start a boot to a minimum so I checked there and found quicken, recently added prog, had several thing running and when I turned them off the system is back in line!
Thanks again for the help
Brunix
Old May 11th, 2003, 04:23 PM     #6 (permalink)
korgul's Avatar
Glad we could help.
Don't ya just love how programs pull and ET on ya and phone home.
Is It Just Me? (3030)
Forty-six years ago today (12)
windows vista security holes (16)
Internet Lost (5)
Nvidia GTX 260 problem (2)
Delete an OS (8)
Open With ..... Win7 (3)
Internet Lost (5)
virus blocking exe. files (1)
Print spooler problem (16)
webcam (0)
upgrade for hp a6101 (0)
Virus advise (8)
