Thread: Help! No Control Panel
October 3rd, 2003, 02:32 AM #1
My lap top is acting up !!! I can not seem to access the control panel, everytime I try to open it up the Search Flash Light comes on looking for the folder and never finds it!!!(Win 98, I know it is ancient)
October 3rd, 2003, 12:57 PM #2
October 3rd, 2003, 12:59 PM #3
You can't bring it up thru Windows Explorer?
WB
October 3rd, 2003, 01:04 PM #4
use the find command to look for *.cpl
these files should be located in the windows/system directory
if they come up in the find window then try clicking on them individually and see if they open the corresponding control panel functions"the chief cause of problems is solutions!"
October 3rd, 2003, 01:08 PM #5
is this a recent problem or inherited hardware? 'coz if you don't know the history of the lappy, then it is possible that a previous user has disabled the control panel, using software such as the security features of system mechanic ( www.iolo.com ). even if it has not been specifically disabled, then it may be worth disabling it yourself then re-enabling it to jump start it back into life.(reboots in between changes) or a registry repair tool may help.
October 3rd, 2003, 04:34 PM #6
Well I can acess everthing through the find"*.cpl" that will get me going for now untill I find out what happend
October 4th, 2003, 01:35 PM #7
Maybe everythings been disabled? There is a reg key to remove sections from control panel, and to add others. It may be worth using tweakui as its a bit easier. IDK where you could download tweakui for 9x now though. :/
Does it work if you type "control" into a run box?_____
NuKeS
October 4th, 2003, 01:54 PM #8
the more likely culprit is a damaged *.cpl file
to find out --- move the *.cpl files from the sytem directory to a temp folder that you create
after they have been removed try to open the control panel
if it opens it will be empty but that will be ok post your results"the chief cause of problems is solutions!"
October 6th, 2003, 01:17 AM #9
I have no idea how this happend but, it was a cookie that was causing the problem??
It works fine after I found it and deleted it...
Thganks guys
October 6th, 2003, 04:17 AM #10Member
- Feb 2003
- 262
Was going to say us a up to date virus/trojan scan on it but its sorted...til the next time.
Peace.In the End, we will remember not the words of our enemies, but the silence of our friends.
October 6th, 2003, 04:22 AM #11Retired mostly.
- Oct 2001
- Location
- Finland
- 5,150
Type -> start->run->control
if nothing happens, something must've deleted your control panel.
(it should be in %systemroot%\system32\control.exe)
You might be able to access it by copying it from another w98 system. .cpl files are extensions, err.. shortcuts to different things displayed in control panel.
-M
I had grabbed a cheap SD card that size to try as ReadyBoost on my mother's laptop, to see if it would be worth putting a SSD in there. Unfortunately, it refuses to run as RB partway through the...
