Join TechIMO for Free!
Currently Active Users: 1618
Discussions: 182,808, Posts: 2,184,189, Members: 225,604
Old January 1st, 2002, 12:39 PM   Digg it!   #1 (permalink)
2 Word 2000 Problems
1. How do I change Word2000 document format. When I open a fresh page, I have a phone number already inserted, and not a completely blank page. Somehow it was put in the blank document and saved as a default. Where do I go to change and get rid of this.
2.I am using Word 2000. How do I change the Feed To Option: to default tray (auto sheet feeder)option, when printing envelope address. I have to reset each time I print an envelope. It is currently set to Auto Sheet Feeder.
kidkasha is offline   Reply With Quote
Old January 1st, 2002, 12:44 PM     #2 (permalink)
ᅟᅠ
1. Make a blank document (or however you'd like the template to be) then chose "Save As..."
Then from the "Save as Type" drop down list, choose *.dot (document template) and save it as Normal.dot
OuTpaTienT is online now   Reply With Quote
Old January 1st, 2002, 01:03 PM     #3 (permalink)
OutPatient that did not work. I just want the page to open blank when I select a blank document page.
Old January 1st, 2002, 01:09 PM     #4 (permalink)
The Mad Redhatter
storm2k's Avatar
Send a message via ICQ to storm2k Send a message via AIM to storm2k Send a message via MSN to storm2k Send a message via Yahoo to storm2k
what you have to do is redo your normal.dot template. that's what word uses to create blank documents.
storm2k is offline   Reply With Quote
Old January 1st, 2002, 01:09 PM     #5 (permalink)
PonzSpyder's Avatar
Send a message via AIM to PonzSpyder Send a message via Yahoo to PonzSpyder
Try going into Tools/Options and then check out the file location tab. There should be a location for "Startup", thats where you need to put that normal.dot file
EDIT: Oops, forgot about the other question...
Did you look in Tools/Envelopes and Labels? Click on the Options Button and than look at the settings under the "Printing Options" tab.
hope this helps and good luck
"It's only after we've lost everything that we're free to do anything"
www.rjponzio.com
PonzSpyder is offline   Reply With Quote
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Is It Just Me? (10219)
Opinions on this build (9)
How do you drink tea? (23)
E3110 (8400) O/C (11)
Who's contributing to whom in the R.. (12)
Damn the Constitution, guns should .. (85)
Monitor or TV? (0)
Join Seti's TechIMO.com (392)
Samsung TV changes channel (3)
Just a quick question (0)
I Fold, Do You? (60)
Weird lag in ATI Radeon HD 3850.. (3)
Alienware PC (0)
(HELP) Virus/Trojan [pop-up err.. (3)
FolderSpam: 8/11 (119)
GIGABYTE GA-EP45T-DS3R,& C2.. (0)
FS: IBM t42 laptop, Dell 6000 n.. (0)
