January 2nd, 2004, 10:25 AM #21
rheteric,
I stopped by work today and picked up the KB articles we used to fix the registry problem. You might find these links useful if your problem hasn't been fixed.
- How to Recover from a Corrupted Registry That Prevents Windows XP from Starting - http://support.microsoft.com/default...b;en-us;307545
- How To Install and Use the Recovery Console in Windows XP - http://support.microsoft.com/default...b;en-us;307654
- How to Gain Access to the System Volume Information Folder (includes the link for the Boot-up floppies) - http://support.microsoft.com/default...b;en-us;309531Last edited by TM12; January 2nd, 2004 at 10:28 AM.
January 2nd, 2004, 10:35 AM #22
This probably help u guys if you have occur some of these problems: http://www.easydesksoftware.com/syshelp.htm
Also this for clear details: http://sft-cyber.com/Corr%20Reg.htm
I have create a thread about this long ago but I can't remember where it was now
January 2nd, 2004, 02:04 PM #23Member
- Jan 2002
- 30
Gentlemen....
I am pleased to announce that the problem is resolved. Thanks to TM12 for directing me to the appropriate Windows XP KB page!!! You and the people of TechIMO made my life a whole lot easier by your knowledgeable support and tenacity in this issue's resolution. Thanks!!!
-rheteric
BTW: TM12, It was the link you posted 12-30-2003 04:03 PM that held the answer. Thanks for going out of your way for those other articles; I'm sure they will be appreciated, too.Last edited by rheteric; January 2nd, 2004 at 02:12 PM.
January 2nd, 2004, 03:11 PM #24
Happy to hear it is resolved!
Thanks to TM12 and Dj-Icer for finding links that I wasn't aware existed
- rp
January 2nd, 2004, 03:34 PM #25
Glad to hear it, glad to be of assistance, and glad that Microsoft has made the process easier. I got a lot from this thread, too!
Happy computing all!
August 6th, 2004, 06:34 PM #26Junior Member
- Aug 2004
- 8
TM12, i was reading the forum, and i couldnt find the link that rheteric referd to when he said that it fixed his problem, do u think u can repost, it, or help me out. my issue, is that i need to get into windows, to back up my files before i format, but i get this c:\windows... is currupt or missing error
Pls help if poosible
August 6th, 2004, 07:20 PM #27Banned
- Jul 2004
- 143
The last item SYSTEM is one of your registry files. Next to SOFTWARE it is the largest registry file. Do you have a registry backup?
Originally Posted by rheteric
August 7th, 2004, 03:39 AM #28Junior Member
- Aug 2004
- 8
re:Stupid XP
Umm, nope i have nothing backed up. im an idiot i know. surly not a mistake that will be repeated, my issue of course is basically finding a way to boot into windows, just to back up *deleted* i need on my hdd. it would be nice, if it were possible not to format..
any help would help
Eli
Profanity is not permitted in the forums - Fingers / TechIMO Moderator TechIMO FAQ
August 7th, 2004, 10:28 AM #29
It appears Microsoft has taken down the article that TM12 posted, so beware, Microsoft might have done it because there is a problem with the article. That said, procede at your own risk!
Credit goes to profman on the sillydog.com forums
Microsoft KB823614:
Originally Posted by profman
August 7th, 2004, 01:38 PM #30Junior Member
- Aug 2004
- 8
hey, yah ive seen that before, but it dosnt help. when i type it it says " the parameter is invalid, try th /? for help. Thats the error i always get, and iv tried it so many times. Also if i try to re-install windows over the currunt version, it wont let. it dosnt even recognize that windows is installed on the current hdd. tells me i have to format it to continue.
any ideas?
August 7th, 2004, 01:47 PM #31
Read it again, I think the original KB article from Microsoft was incorrectly spaced. The 3 commands in step 5 should have been seperated, so I edited my post to fix the spacing. The 3 commands should be entered one at a time:
CD C:\Windows\System32\Config
REN system system.old
COPY C:\Windows\Repair\system
August 7th, 2004, 02:12 PM #32Junior Member
- Aug 2004
- 8
yah, after i type the first line
cd c:\windows\system32\config
and press enter i get
"the path or file specified is not valid"
August 7th, 2004, 02:14 PM #33
August 7th, 2004, 02:15 PM #34Junior Member
- Aug 2004
- 8
sorry, then when i try
ren system system.old
i get.
"the rename failed"
then Copy c:\windows\Repair\system
i get
"access is denied"
it hangs after every command
August 7th, 2004, 02:17 PM #35Junior Member
- Aug 2004
- 8
same issue. with the Winnt
August 7th, 2004, 03:57 PM #36Junior Member
- Aug 2004
- 8
Any new ideas?
August 7th, 2004, 04:46 PM #37Junior Member
- Aug 2004
- 8
K, new devlepment, i was playn with some stuff, and i got that to work, and everything looked fine, windows restarted, and logo came up, then it froze black and now i get a new message
"windows could not start because the following file is missing
<windows root>\system32\hal.dll."
Brutal soccer fight! Be warned.
