Have you tried installing WinXP on every hard drive?
Have you tried installing WinXP to a hard drive attached to a standard IDE port, not the RAID ports, then moving the drive to the RAID port? (changing your bootup sequence in your BIOS, of course)
No hardware added since original install?
do you have any pci cards installed? I had a similair problem and it ended up being a modem card, and one before that it was the nic card. Apparently windows will stall or create errors if it cant find a driver to match those cards when reinstalling. I gave it my bes shot. Hope it helps!
