Results 1 to 6 of 6
    Ultimate Member fyxxer32's Avatar
    Nov 2001
    1,320
    XP Pro or is it IE 6.0 ?
    I upgraded this machine from Win2K to XP Pro, downloaded all the bazillion patches etc too.
    My question is, before the upgrade , if I hovered over a link , down on the lower left of the window, by the task bar it would usually show what the link was. Now its gone, what do I need to change? I like knowing where I may be going.
    10,821
    check under tools/internet options/advanced....there are some options for underlining links (but I dont think thats it,lol)..but look around in there anyway.....not sure though cuz mine does it and I didnt have to do anything to it....but Im on xp pro.
    Could it be maybe a direct x thing? Or related to scripts or script blocking?
    (wild guesses, sorry)
    JP
    1010011010 jmichna's Avatar
    Chicagoland IL
    3,249
    On IE's menu bar, select View... then make sure "Status Bar" is checked.
    10,821
    ahhh, lol
    Nov 2001
    1,320
    The status bar thing did the trick. Thanks. You're all geniuses and that's why I keep coming back!
    Member thegladiatorgy's Avatar
    Oct 2002
    Georgetown, Guyana
    383
    Lol JP
