Join TechIMO for Free!
Topic: my system is configured to open outlook express on startup and dialup automatically it also loads norton internet security and mother board monitor. this usually takes 90 seconds for the whole process. for about a week now...
Thread Tools
Currently Active Users: 1554
Discussions: 186,643, Posts: 2,224,032, Members: 229,778
Old January 18th, 2004, 11:40 AM   Digg it!   #1 (permalink)
waynezo's Avatar
slow bootup xp home
my system is configured to open outlook express on startup and dialup automatically it also loads norton internet security and mother board monitor. this usually takes 90 seconds for the whole process. for about a week now outlook express loads and there is a 60 second pause before norton loads and then the dialup occurs increasing bootup time to 2.5 to 3 minutes. Yesterday I did the critical xp updates and the next few times bootup was 90 seconds. today I am back to the slow bootup.
is there a fix for this?
My system,
Athlon xp2400 cpu
Gigabyte GA-7vaxp mb with promise onboard raid controller
Kingston value ram 512ddr pc3200 400mhz
Dual 80gig maxtor hd's 7200rpm ata 133 raid 0
Artec 16X DVD-ROM
Cyberdrive 40X16X48 CDRW
Verbatim 2.4X DVD+RW/R
ATI all in wonder 8500dv AGP primary video card
VisionTek XTASY radeon 9100 64mb ddr PCI 2nd video card
Nokia 21" 445Xpro CRT Monitor
KDS 17" visual sensations CRT monitor
Antec 430 watt true power ps
Ahanix platinum xp steel case
Windows xp home sp1
Waynezo
waynezo is offline   Reply With Quote
Old January 18th, 2004, 11:59 AM     #2 (permalink)
Outlook Express starting loading slow about three weeks ago.
I had other problems, so I did a clean install. OE worked normal right through win update, but when I installed Norton and updated it OE went back to slow loading. I haven't fixed it yet either. I have read other threads with recent problems with Norton Update but they did not mention this problem.
stroyal is offline   Reply With Quote
Old January 18th, 2004, 12:19 PM     #3 (permalink)
skating away.........
doddsy's Avatar
i had similar problems after installing macafee av, really slowed down my startup. had to do a full recovery in the end.
have you tried msconfig?
just about every program u install will set itself to run at startup when u probably don't need it too.
if you tidy up your start up it might help.
click: start, run,...........then type msconfig and click the startup tab...........have a look for programms loading at startup and uncheck any that u are SURE that u don't need. then reboot.
i'd think about NOT having oe and dial up and that drive checker at startup unless u really need them, and unless u use messenger get rid of it too.
doddsy
doddsy is offline   Reply With Quote
Old January 19th, 2004, 02:59 AM     #4 (permalink)
If you disable messenger it will slow outlook express down while it searchs for it .
Also antivirus settings can slow down the os very much if set to check programs prior to opening them .
Good Luck .
barginhunter is offline   Reply With Quote
Old January 19th, 2004, 08:58 AM     #5 (permalink)
I did disable messinger, that must be it.
I think on my last install I uninstalled it. This time I uninstalled it before I installed word and I can't uninstall the one word installed.
Old January 21st, 2004, 09:12 AM     #6 (permalink)
http://www.kellys-korner-xp.com/xp_o.htm
Tip: Outlook Express Runs Slowly after Disabling/Removing Messenger. Only 3 Registry edits are required to stop Messenger and get rid of the delay in OE.
jmatt is offline   Reply With Quote
Old January 21st, 2004, 09:53 AM     #7 (permalink)
Thanks for that link jmatt, Outlook Express opens instantly again.
Old January 21st, 2004, 11:30 AM     #8 (permalink)
now my problem is that there are to many processes that i dont need. i always have to end them when i boot up my computer but when i boot it up it takes a while for everything to load and for the names of the processes to show... so my problem is how do i get rid of all those nasty processes for good?
xETx is offline   Reply With Quote
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Is It Just Me? (16959)
FolderChat: Weekend time again! (284)
The F word (under-utilized or horri.. (23)
So GLAD winter's finally here !! (13)
Folderchat Weekday thread (373)
Super folding (17)
Popular Online Pc Retailers (12)
AM2+/AM3 (9)
PSU recommendation, think mines is .. (14)
Sapphire Radeon HD 3850 512Mb A.. (0)
***BUY ACOMPLIA BRANDED ONLINE.. (0)
$0.59 PILL buy cheapest acompli.. (1)
Cheap air jordan,air max,air fo.. (1)
$0.33 PILL buy propecia online .. (0)
Desktop Clutter (1)
cheap jordan shoes (0)
Graphics Card Icon In Sys Tray .. (3)
Addon DSL wireless router (4)
Seald copy of windows 95 for sa.. (0)
Various items for sale (1)
Woot-off (5)
