Thread: Slow Xp Pro
January 23rd, 2004, 06:38 PM #1Junior Member
- Dec 2003
- Location
- London
- 22
Slow Xp Pro
Xp has slowed up ! (must be old age)
I get to the login screen pretty damn fast, type the password then sit back, make a tea, have a bath etc. About a minute later the old desktop appears.
I know a minute is not a long time, but it seems it as you sit and wait - and this has only happened recently. My start-up doesn't contain a lot - but, Task Manager is showing 23 processes running. Is this the problem?
Help
January 23rd, 2004, 06:45 PM #2I'd say that is where your problem lies. run a good antivirus and spybot or adaware or both or kill some of those processes of and see if that helps. Also check to make sure your not having any device conlifcts {if there is any new hardware} and that you have the latest drivers and updates for all your hardware and softwarebut, Task Manager is showing 23 processes running. Is this the problem?
January 23rd, 2004, 07:20 PM #3Member
- Oct 2003
- 60
January 23rd, 2004, 07:53 PM #4
I don't know that 23 running processes will slow you down-depends on the processes. 5 running processes will slow you down if they take awhile to complete on startup. I have 29 processes on startup, and my boot times are always very quick...
I agree that scanning for spyware would be a good start to the process of elimination, as well as a good virus scan. Your system specs might help...is your filing system FAT32 or NTFS? And how much free space do you have on your HDD?
Fat32 will need to be defragged more often, and will show a performance decrease as the drive has less free space...
Have you installed any updated drivers lately? Some drivers not digitally signed by Microsoft can cause a system to hang before booting...case in point--drivers for the Gamesurround MuseXL sound card.
There's a utility called BootVis that can help troubleshoot startup hangs...I don't have the specific link right off hand, but I know you can get a copy at kellys-korner.com
*EDIT* Here's the link for BootVis:
http://www.kellys-korner-xp.com/xp_tweaks2.htm#util
At the bottom of the page, under "Utilities for XP"Last edited by Gettinbye; January 23rd, 2004 at 08:10 PM.
4200+x2,a8n-sli premium,2gig pc3500,7800gt,7x sata hdds (160gig-320gig),2x dvdrw,630w psu,gigabyte aurora
Stupid weather.
