Tech Support Forums - TechIMO.com
Tech Support Forums - TechIMO.com (http://www.techimo.com/forum/)
-   Applications and Operating Systems (http://www.techimo.com/forum/applications-operating-systems/)
-   -   RPM Rebuild....What Am I doing Wrong? (http://www.techimo.com/forum/applications-operating-systems/9821-rpm-rebuild-what-am-i-doing-wrong.html)
Germ January 13th, 2002 12:00 PM
I'm trying to rebuild Galeon.
rpm --rebuild galeon-1.10-1.src.rpm
no such file or directory
The file is there, I downloaded it, I checked it, I know the path to it. What's up?
Germ
pbharris January 13th, 2002 01:06 PM
hi Germ,
You need to be in the same directory or specify the path to the rpm, e.g. rpm --rebuild /home/germ/galeon-1.10-1.src.rpm if it is in you home directory and you are not, you also need to be root because it puts the built rpm in /usr/src/<distroname>/RPMS/i386/ if you don't specify architecture, if you knew that already then sorry for giving too much info.
here are some other hopefully helpful rpm commands
http://www.linuxjunior.org/cgi-bin/p...=Display&id=35
Germ January 13th, 2002 02:10 PM
OK.....How did you know it was /home/germ/?? j/k :D
What I did was su and then cd to my home directory. Do I need to login as root to rebuild?
storm2k January 13th, 2002 02:14 PM
no... if you su, you're considered root until you type exit and go back to being just watever you logged in as.
pbharris January 13th, 2002 02:16 PM
use su - it picks up root entvironment, but that should not matter.
this is pretty weird, anychance it it in another directory or a mis-spelling? i know dumb question...but i gotta ask
Germ January 13th, 2002 02:31 PM
no...checked all that. Really weird.
pbharris January 13th, 2002 03:03 PM
try putting in the explicit path even if you are in the same directory...
ChoaticWhisper January 13th, 2002 03:16 PM
Just gotta ask have you tried changing to that directory and then
rpm --rebuild ga{TAB} to see if it will fill in the rest.
Germ January 13th, 2002 03:21 PM
This is really weird. I used the explicit path and still get the same error. I'm going to re-download the source and try again. Will post back.
Thanks,
Germ
Germ January 13th, 2002 04:33 PM
re-downloaded the source RPM.
tried to rebuild, su and also logged in as root
removed rpm-rebuilder and reinstalled
tried again and again.
same error each time- no such directory or file
Mandrake 8.1
I'm stumped.
TechIMO™ Copyright 2007 All Enthusiast, Inc.
