Results 1 to 11 of 11
    Senior Member Southern Belle's Avatar
    California
    665
    Angry HELP! Winxp wont install ATI Radeon 7000 vid card!
    heyal,
    I built a system which is a Intel P4 1.8 ghz with 768 ddr ram, ATI Radeon 7000 vid card, 2 hd's 1x20gig and 1x 60gig, 1cdrw and 1 floppy. Running WinXp, no internet connection so no updates can be done.
    I have tried and tried and tried to install the ATI Radeon Drivers but winxp fails to utilize the *.inf files or the setup from the driver program. I've tried both auto and when doing that I get error msg [dayuuum now i forgot what msg was] but saying its incomplete & to use generic vga before setup.
    when trying to do it manually by adding hardware-select from list it shows ati but only the rages and all in wonder and some max fury brand. when trying to use the "have disk" i point it to the directories with the .inf files and nothing shows up in list. I 've tried to right click inf files and click install but that doesnt seem to help.
    when trying to play game thats installed get error message to check dx version or that video card is compatible.
    Please help! i've tried everything i can think of with no luck.
    any help is greatly appreciated,
    thank you,
    southern belle
    Thank You,
    Southern Belle
    "I Am A GOD In Training .... Just Wait Till It Catches On!"
    Rather Large Member Beemer's Avatar
    Vernon, BC, Canada
    10,197
    Remove all drivers for your display card and reboot your machine and allow WinXP to install the VGA drivers.
    Now go and use the setup program for the ATI card.
    Cheers!
    Ultimate Member meese's Avatar
    Jun 2003
    NJ
    2,467
    You may need to use winzip to extract the files from the ati file (even if its a EXE file) to a new folder. Then manually install the drivers. When asked for the location, point to the folder you just created. I had to do it this way on several occasions.
    Jan 2004
    Fontana
    20
    If you need help tell me
    California
    665
    heyal,
    well this responds to:
    re: removing all drivers for card ...they're are none except the directory where the exe file expands for installation. I have previously removed that too but still no luck.
    re: expanding exe and point windows to file...i've done this and tried to manually install but still no luck.
    re: need help ....OH YES INDEED I DO NEED YOUR HELP! lol
    keep posting and I'll keep trying.
    oh there is no display adapters listed in the device manager and couldnt get windows to list right one.
    the drivers for xp are from ati website.
    thanks so very much, i'll keep checking back for new posts.
    southern belle
    Thank You,
    Southern Belle
    Jan 2004
    Fontana
    20
    Sourthen Bell this is Hughes do you need help?
    California
    665
    heya hughes,
    yes I need your help, im lost with this
    sb
    Thank You,
    Southern Belle
    Jan 2004
    Fontana
    20
    Sourthen Bell what is your ploblem.
    dnuof-dna-tsol lost-and-found's Avatar
    Left Coast...aka CA
    3,103
    She posted it in her top post ^
    California
    665
    Heyal,
    for an update to video card prob i'm going to have to get a newer card, xp just won't take it or rather accept it. no matter what drivers i use wether it be orig, updated, 3rd party nothing.
    so now to find an extreeeemly affordable video card lol
    thanks for all the help! {{{hugs}}}
    southern belle
    Thank You,
    Southern Belle
    California
    665
    heyal,
    sorry for the late update lol been going thru my old posts and updating.
    problem solved!
    i put a gforce 4600 ti card in and didnt take it either but finally got service packs 1 & 2 which 2 was the ace in the hole, but it took it and installed it.
    thanks for all the help,
    sb
    Thank You,
    Southern Belle
