CCNA Exploration Activity 6.4.3 Help  | |
April 7th, 2009, 03:12 AM
HI
I have just started on the activity 6.4.3.. Can anyone give me the right answers so that i know how i am doing with it..I have attached the file with topology diagram.
Thanks in advance.
The activity is as follows: Step 1: Examine the addressing assignment for the HQ LAN1 subnet and answer the questions below: 1. How many IP addresses are needed for the HQ LAN1 subnet? __________ 2. How many IP addresses are available in the currently assigned subnet? __________ 3. Will the currently assigned subnet fulfill the size requirement for the HQ LAN1 subnet? _______ 4. If the answer to the previous question is no, propose a new subnet mask that will allow for the correct number of IP addresses. ________________________________ 5. Does the subnet overlap with any of the other currently assigned networks?_______ 6. If the answer to the previous question is yes, propose a new subnet mask that will allow for the correct number of IP addresses without overlapping into any other subnets. ________________________________ Step 2: Examine the addressing assignment for the HQ LAN2 subnet and answer the questions below. 1. How many IP addresses are needed for the HQ LAN2 subnet? __________ 2. How many IP addresses are available in the currently assigned subnet? __________ 3. Will the currently assigned subnet fulfill the size requirement for the HQ LAN2 subnet? _______ 4. If the answer to the previous question is no, propose a new subnet mask that will allow for the correct number of IP addresses. ________________________________ 5. Does the subnet overlap with any of the other currently assigned networks?_______ 6. If the answer to the previous question is yes, propose a new subnet mask that will allow for the correct number of IP addresses without overlapping into any other subnets. ________________________________ Task 2: Examine the Addressing for the Branch1 LANs. Step 1: Examine the addressing assignment for the Branch1 LAN1 subnet and answer the questions below. 1. How many IP addresses are needed for the Branch1 LAN1 subnet? __________ 2. How many IP addresses are available in the currently assigned subnet? __________ 3. Will the currently assigned subnet fulfill the size requirement for the Branch1 LAN1 subnet? _______ 4. If the answer to the previous question is no, propose a new subnet mask that will allow for the correct number of IP addresses. ________________________________ 5. Does the subnet overlap with any of the other currently assigned networks?_______ 6. If the answer to the previous question is yes, propose a new subnet mask that will allow for the correct number of IP addresses without overlapping into any other subnets. ________________________________ Step 2: Examine the addressing assignment for the Branch1 LAN2 and answer the questions below. 1. How many IP addresses are needed for the Branch1 LAN2 subnet? __________ 2. How many IP addresses are available in the currently assigned subnet? __________ 3. Will the currently assigned subnet fulfill the size requirement for the Branch1 LAN2 subnet? _______ 4. If the answer to the previous question is no, propose a new subnet mask that will allow for the correct number of IP addresses. ________________________________ 5. Does the subnet overlap with any of the other currently assigned networks?_______ 6. If the answer to the previous question is yes, propose a new network address that will allow for the correct number of IP addresses without overlapping into any other subnets. ________________________________ Task 3: Examine the Addressing for the Branch2 LANs. Step 1: Examine the addressing assignment for the Branch2 LAN1 subnet and answer the questions below. 1. How many IP addresses are needed for the Branch2 LAN1 subnet? __________ 2. How many IP addresses are available in the currently assigned subnet? __________ 3. Will the currently assigned subnet fulfill the size requirement for the Branch2 LAN1 subnet? _______ 4. If the answer to the previous question is no, propose a new subnet mask that will allow for the correct number of IP addresses. ________________________________ 5. Does the subnet overlap with any of the other currently assigned networks?_______ 6. If the answer to the previous question is yes, propose a new subnet mask that will allow for the correct number of IP addresses without overlapping into any other subnets. ________________________________ Step 2: Examine the addressing assignment for the Branch2 LAN2 and answer the questions below. 1. How many IP addresses are needed for the Branch2 LAN2 subnet? __________ 2. How many IP addresses are available in the currently assigned subnet? __________ 3. Will the currently assigned subnet fulfill the size requirement for the Branch2 LAN2 subnet? _______ 4. If the answer to the previous question is no, propose a new subnet mask that will allow for the correct number of IP addresses. ________________________________ 5. Does the subnet overlap with any of the other currently assigned networks?_______ 6. If the answer to the previous question is yes, propose a new network address that will allow for the correct number of IP addresses without overlapping into any other subnets. ________________________________ Task 4: Examine the Addressing for the Links between Routers. Step 1: Examine the addressing assignment for the link between the HQ and Branch1 routers and answer the questions below. 1. How many IP addresses are needed for the link between the HQ and Branch1 routers? _______ 2. How many IP addresses are available in the currently assigned subnet? _______ 3. Will the currently assigned subnet fulfill the size requirement for the link between the HQ and Branch1 routers? _______ 4. If the answer to the previous question is no, propose a new subnet mask that will allow for the correct number of IP addresses. ________________________________ 5. Does the subnet overlap with any of the other currently assigned networks?_______ 6. If the answer to the previous question is yes, propose a new subnet mask that will allow for the correct number of IP addresses without overlapping into any other subnets. ________________________________ Step 2: Examine the addressing assignment for the link between the HQ and Branch2 routers and answer the questions below. 1. How many IP addresses are needed for the link between the HQ and Branch2 routers? _______ 2. How many IP addresses are available in the currently assigned subnet? _______ 3. Will the currently assigned subnet fulfill the size requirement for the link between the HQ and Branch2 routers? _______ 4. If the answer to the previous question is no, propose a new subnet mask that will allow for the correct number of IP addresses. ________________________________ 5. Does the subnet overlap with any of the other currently assigned networks?_______ 6. If the answer to the previous question is yes, propose a new network address that will allow for the correct number of IP addresses without overlapping into any other subnets. ________________________________ Step 3: Examine the addressing assignment for the link between the Branch1 and Branch2 routers and answer the questions below. 1. How many IP addresses are needed for the link between the Branch1 and Branch2 routers? _______ 2. How many IP addresses are available in the currently assigned subnet? _______ 3. Will the currently assigned subnet fulfill the size requirement for the link between the Branch1 and Branch2 routers? _______ 4. If the answer to the previous question is no, propose a new subnet mask that will allow for the correct number of IP addresses. ________________________________ 5. Does the subnet overlap with any of the other currently assigned networks?_______ 6. If the answer to the previous question is yes, propose a new subnet mask that will allow for the correct number of IP addresses without overlapping into any other subnets. ________________________________ Task 5: Document the Corrected Addressing Information. Record the corrected addressing information in the Addressing Table below. Subnet Number of IP Addresses Needed Network Address HQ LAN1 16,000 HQ LAN2 8,000 Branch1 LAN1 4,000 Branch1 LAN2 2,000 Branch2 LAN1 1,000 Branch2 LAN2 500 Link from HQ to Branch1 2 Link from HQ to Branch2 2 Link from Branch1 to Branch2 2
Reason: Better title
April 7th, 2009, 04:53 AM
| | A hero in training
Why dont you put your answers down and maybe someone can correct you |
April 7th, 2009, 12:55 PM
| | THE Gimp Clown Fish!
| Quote:
Originally Posted by GroundZero3 Why dont you put your answers down and maybe someone can correct you | I think he wants us to do the work for him. |
April 7th, 2009, 01:23 PM
| I am stuck doing this activity and can not understand it. That's the reason I want someone to explain it to me how it works. Thanks for reply. |
