May 4th, 2010, 08:54 AM #1
Oil disaster (why don't they simpy cut the pipe and cap it?
I am amazed that they do not have the tech to do this.
it would seem no challenge at all to attach a robot to the riser pipe. It is a fixed diameter and a predictable surface.
for technology today it also would not seem to be a challenge to cut a pipe remotely to a nice clean edge.
there should be no challenge in aligning a sleeve section with a valve attached over the pipe with a hydraulic robotic arm.
Clamping technology would not seem to be a challenge either and finally turning off the valve should not be difficult.
Control systems and such already exist.
Why do you think they could not fabricate something like that in a few hours let alone there should be something like this already.
School me on the subject anyone who might have a guess as to why this is not reasonably feasible
May 4th, 2010, 09:22 AM #2
It would be similar to trying to cork some of the people in this forum. Just too darn much coming out to get the job done right.
May 4th, 2010, 09:23 AM #3
The pipe is broken in 3 different places, NOT to mention it is bent all kinds of out of shape, laying where it fell on the bottom of the ocean floor ~5000 feet below the surface of the ocean.
The first/lowest is above the cutoff valve just above the floor of the ocean - the one they cant shut.They say technology slows down for no one. I know it outruns my wallet. I figure its because my wallet isn't light enough yet.
dulce bellum inexpertis
May 4th, 2010, 09:26 AM #4
Graphic courtesy of NOLA: Breaking Local News from New Orleans, Louisiana – NOLA.com
Originally posted by Sweet in the other thread.They say technology slows down for no one. I know it outruns my wallet. I figure its because my wallet isn't light enough yet.
May 4th, 2010, 09:34 AM #5
Thank you for that!
Obama: The rich have the Federal Reserve and the poor have Harry Reid... LOL. Life really is unfair!
May 4th, 2010, 10:14 AM #6
Since the thing isn't about to be clogged, why can't they just light a match and throw it on the oil and let it burn before it reaches land?
May 4th, 2010, 10:15 AM #7
Because they had problems with doing a control burn with the weather
May 4th, 2010, 10:25 AM #8
I'm sure it makes sense, but to the uninformed (namely me), it sounds hilarious that they are having a hard time doing a controlled burn of a oil in the middle of the ocean.... It would almost seem that there is nothing else to catch on fire for miles and miles around.... of course I realize that there is alot more to it than that (heck, do you want to be on a boat when a flaming wave comes crashing onto the deck?), but it just sounds funny when you first hear it.
I don't like signatures.
May 4th, 2010, 10:28 AM #9
Isnt the oil hitting the LA shores now?
Weather Hampers Efforts to Burn Some of Oil Spill - NYTimes.com
Crews had been hoping that controlled burns would help ease the impact of the oil reaching the fragile Louisiana coast. The process, called an in-situ burn, consists of corralling concentrated parts of the spill in a 500-foot-long fireproof boom, moving it to another location and burning it. It has been tested effectively on other spills, but weather and concerns about marine ecosystems can complicate the procedure.
A burn does not get rid of the oil entirely. It leaves waxy residue that can either be skimmed from the surface or sink to the bottom of the ocean.
May 4th, 2010, 10:47 AM #10Banned
- Dec 2005
- Location
- East Coast, USA
- 240
Rham Emanuel said it best fellas.
"you never want to let a crisis go to waste. What I mean by that, is that a crisis allows you to do things that you normally would not be able to do otherwise."
May 4th, 2010, 10:48 AM #11
hmmmm. So even though we can't eat all the dead animals/fish/birds caused by the crisis we can still have a big BBQ anyway...Count me in - NOT.
May 4th, 2010, 11:00 AM #12
I'm surprised they can't get a vaccume type dredger or something to suck up some oil.
May 4th, 2010, 11:12 AM #13BP struggles to stop Gulf of Mexico oil leakThe London-based energy giant, under pressure from Washington to limit the damage, completed the first of three massive steel and concrete domes it will try to place this week over one of three leaks nearly a mile under the water's surface.
May 4th, 2010, 11:46 AM #14
the break after the blow out preventer is where I am talking about
I would think they could build a robot that attaches to a pipe... Cut it. and cap it with a valve. once capped they could shut the valve and begin corrective action.
I envision a device that clamps on to the pipe. using remote cables like rov. cuts the pipe, now you have one leak.
now on that clean cut you slip over a coupling clamp it and on the coupling you have a valve that you shut.
the operation seems rather easy. of course they don't have this robot but it does not seem like an overly complex one to build. attach a robot to the pipe drive to the desired location run a blade around the pipe like those copper tubbing cutters on steroids. attach a second robot drive it to the scene and with a hydraulic arm slip a coupling in place.
Even if the tech does not exist today. shouldn't it be possible and even rather simple when dealing with the budget of an oil company.
A hell of alot cheaper than allowing an oil leak for weeks.Last edited by Epidemic; May 4th, 2010 at 11:55 AM.
May 4th, 2010, 01:45 PM #15
Ok so they are trying to do my method. although I think they are having a problem because they are not using my model robot
they are using them floating things when they should just clamp on to the pipe.
BP working to cap one of three leaks in oil spill | NBC13.com
May 4th, 2010, 02:03 PM #16
What you are missing Epi is that this pipe is 5,000+ feet down. They can't just send any 'ol robotic submersible down there to cut a pipe and place a cap over a high pressure oil leak. Plus, the end of the pipe by the failed shutoff is not easily accessible, there is a lot of other equipment at the pipe base to work through.
The timing of death, like the ending of a story, gives a changed meaning to what preceded it. -Mary Catherine Bateson-
May 4th, 2010, 02:04 PM #17
WOW Epi - you're a famous guy. You type a few thoughts and before you know it BAM - you're in the News. COOL.
May 4th, 2010, 03:03 PM #18
well you see they did already accomplish the primary task of going down there. and cutting the pipe off. they just did it by the far end.
the 5000 foot thing is a problem but BP has lotsa dollars and they have mastered it. but I suspect that they are using a floating platform to cut and cap the pipe which I would think would be much more difficult than a robot attached to the pipe.
I am not saying I could do it but I suspect that I could direct a team how to make a machine that could clamp onto a pipe and manipulate a sleeve on a pipe in extremely adverse conditions. As far as the wreckage on the bottom there you have me. so far I have only seen renditions of it which indicate the pipe fell down relatively sideways and is laying across the bottom with the rig some distance away from the blowout preventer. Obviously that could be a bad representation.
May 4th, 2010, 03:44 PM #19
Epi, what the heck are you talking about?
Even with hundreds of millions of dollars at your disposal, these things take time, not only to plan an implementation but to carry out an implementation. You're talking about building what would actually be a very large, potentially complicated tool that has to be able to be remotely controlled in adverse conditions where even the controllers themselves may not have a solid idea of what the environment is like. BP America's President said, "This is like doing open-heart surgery at 5,000 feet in the dark,". Adverse conditions including total darkness, manipulating vehicles around a large wellhead that is leaking pressurized oil and probably a lot of debris.
May 11th, 2010, 02:13 PM #20
Copper Pipe Condensation
By RituallyPure in forum IMO CommunityReplies: 26Last Post: January 15th, 2011, 03:29 PM -
lead flange pipe
By ibareno in forum Technical SupportReplies: 11Last Post: January 19th, 2009, 07:41 PM -
Oil Pressure & Oil Temp Guage Installation
By usslindstrom in forum IMO CommunityReplies: 2Last Post: July 2nd, 2005, 03:15 AM -
PVC pipe question
By super gerbil in forum IMO CommunityReplies: 13Last Post: February 22nd, 2005, 09:40 PM -
Crab Vs the Pipe!
By GroundZero3 in forum IMO CommunityReplies: 8Last Post: January 30th, 2003, 10:46 PM
Interesting surreal . . . He has made some damn good movies. Would he have been funded? IDK . . .
Roman Polanski may be a...
