Go Back   Tech Support Forums - TechIMO.com > TechIMO Community > Distributed Computing
Problem with ECCp
Currently Active Users: 1163
Discussions: 200,929, Posts: 2,379,148, Members: 246,296
Old April 5th, 2002, 06:27 PM   Digg it!   #1 (permalink)
hav0c's Avatar
Problem with ECCp
I'm having trouble compiling the newest Statsaholic version of ECCp on my Linux box(Mandrake 8.2). I type make x86lCL and get the following error "make: *** No rule to make target `asm/x86_att/inv_p109.S', needed by `eccp109ls'. Stop."
Anyone know what might be the cause of this?
hav0c is offline   Reply With Quote
Old April 6th, 2002, 01:47 AM     #2 (permalink)
HotRod9mm's Avatar
Send a message via ICQ to HotRod9mm
Sorry I can't help. I do know several here run Linux and will be able to help. You could try PM'ing "Spook Eddy" as I know he is up on that Linux....
<edit for a brain fa*t> Do a search in this forum, if I recall someone posted how to set up Linux a while back....
Blaming firearms for violence is like blaming spoons for Rosie O’Donnell for being fat!
HotRod9mm is offline   Reply With Quote
Old April 6th, 2002, 02:34 AM     #3 (permalink)
KenKun's Avatar
Me too .. sorry, but i can't help in linux ..
I just found a thread that might help
http://www.techimo.com/forum/t16929.html
Good Luck
KenKun is offline   Reply With Quote
Old April 6th, 2002, 08:03 AM     #4 (permalink)
iNsAn3 mEMBER
Daft_Ghosty's Avatar
Send a message via ICQ to Daft_Ghosty Send a message via AIM to Daft_Ghosty Send a message via MSN to Daft_Ghosty Send a message via Yahoo to Daft_Ghosty
MereMortal should know.. over at TNT-EXDC.. KnenKun posted a link that should take u in the right direction.. if u still can't get it.. then I would say see if you can get in touch with MereMortal..
In life one must Chill
Daft_Ghosty is offline   Reply With Quote
Old April 6th, 2002, 08:22 AM     #5 (permalink)
Thud's Avatar
Actually, he's at Anandtech.
I think we have a couple of folks (Skuz and EvilRick, maybe?) who run it in Linux. Hopefully they'll be along soon.
FYI: You'd probably have better luck if you indicated it was a Linux related question in the subject.
Best of luck....I'm sure someone will come along before too long! I know squat about Linux.
Thud is offline   Reply With Quote
Old April 6th, 2002, 12:32 PM     #6 (permalink)
I'll download the statsaholic source and have a look at it. I don't know what extras Virus added in, but if you can do without those, you can download myclient.
If Ken_g6's source was just 'stuck in' there, then I have a good idea what's wrong. I had to make some minor changes to get client to compile on linux.
Anyway, I'll be back later....
MereMortal is offline   Reply With Quote
Old April 6th, 2002, 12:43 PM     #7 (permalink)
Space for Sale! :p
eagle1's Avatar
I run the linux client but I have never used the source and compiled it to get the executable, I always use the binary!
boo!
eagle1 is offline   Reply With Quote
Old April 6th, 2002, 02:24 PM     #8 (permalink)
Praetorian's Avatar
Hmm....I just downloaded the Enhanced Linux Client (athlon) from Statsaholic.com and it does not require and compling. In a terminal type tar -xzvf eccp109-xxx-_xx_xx.tar.gz. Then run it untared file buy typging (heres a space) ./eccp109_k If I'm totaly wrong here show me what version you got so I can help ya out more.
Praetorian is offline   Reply With Quote
Old April 6th, 2002, 03:53 PM     #9 (permalink)
Praetorian, I believe that hav0c is trying to build with the latest source code on statsaholic, not trying to get the last linux binary version posted.
I looked at the source code, and here are a few comments:
1) That source code does not have the latest ASM code from Ken_g6. The version I posted does.
2) The difficulties you are running into while trying to compile are what I expected. The files in asm/x86_att don't match with those in the Makefile. It is a problem with the case of the extensions. To make everything consistent, I use the '.S' extension for the assembly files.
Another problem I ran into is that the source uses CLK_TCK to determine iterations per second. I found that in my linux system that value was 1000x too low, so I changed back to the way that Chris had done it before.
3) There are some extras that Virus put in like running in quiet mode, setting the send interval, run time, etc. If you really need these features, then you will have to add them yourself. The easiest thing to try would be to use the source that I modified and put in the statsaholic inter/x86lCL/eccp109-x86lCL.c. I haven't tried this, and probably won't since I am packing for a move across the country.
So, there you have it.
Old April 6th, 2002, 07:04 PM     #10 (permalink)
hav0c's Avatar
Thanks Meremortal
Is It Just Me? (2868)
Obama the Muslim (14)
Regular Build (3)
Fire in DVD (2)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
Virus Doctor Popup? (1)
