Hi all..
I have network and I am using Need for Speed 2 Special Edition, but whne I select NETWORK from game setup, and try to connect it says "No Service Found", so how can I configure it..
I can guess, since it's an older game, it might use ipx/spx for lan play, and not tcp/ip as normal games do.
You might want to check out the manual on what it says about network play.
