i just bought half life platinum edition and every time i try installing it it says C:\WINDOWS\SYSTEM32\AUTOEXEC.NT. The system file is not suitable for running MS-DOS and Microsoft Windows applications. Choose 'Close' to terminate the application. im using windows XP and i dont know what i have to do.
Is there a skip or continue button or is it just close? if there are the other two buttons try pressing them, if it doesnt do anything try pressing them alot, i sometimes get errors like this and it works for me. oh and welcome to the forums
To use these files, download the correct one to your hard disk and then double click it. It will extract the files to your C:\Windows\System32 directory and overwrite the existing ones. Reboot your PC. Note that this fix is for Windows XP only and assumes that Windows is installed on your C: drive.
