Go Back   Tech Support Forums - TechIMO.com > Single and Multiplayer Gaming > General Gaming Discussion
Join TechIMO for Free!
Thread Tools
Currently Active Users: 2189
Discussions: 186,589, Posts: 2,226,838, Members: 230,213
Old November 21st, 2004, 04:04 PM   Digg it!   #1 (permalink)
Question
Problem with starting Call of Duty
Could anybody help me regarding the starting Call of Duty,
I had copy the report of a problem below.What should I do to get started the game??
Thanks in advance,every help is more than welcome.
COD 1.0 build win-x86 Oct 5 2003
----- FS_Startup -----
Current language: english
Current search path:
D:\Goran\Igre\cod\main\pak6.pk3 (3 files)
D:\Goran\Igre\cod\main\pak5.pk3 (4858 files)
D:\Goran\Igre\cod\main\pak4.pk3 (1668 files)
D:\Goran\Igre\cod\main\pak3.pk3 (1992 files)
D:\Goran\Igre\cod\main\pak2.pk3 (694 files)
D:\Goran\Igre\cod\main\pak1.pk3 (2642 files)
D:\Goran\Igre\cod\main\pak0.pk3 (12828 files)
D:\Goran\Igre\cod/main
D:\Goran\Igre\cod\main\localized_english_pak1.pk3 (3736 files)
localized assets pak file for english
D:\Goran\Igre\cod\main\localized_english_pak0.pk3 (1204 files)
File Handles:
29625 files in pk3 files
execing default.cfg
couldn't exec language.cfg
couldn't exec config.cfg
couldn't exec autoexec.cfg
========= autoconfigure
configure.csv: using configuration 2000 cpu MHz 256 sys MB 64 vid MB
execing configure.cfg
fs_basepath is write protected.
fs_homepath is write protected.
Hunk_Clear: reset the hunk ok
...detecting CPU, found Intel Pentium III
Measured CPU speed is 2.40 GHz
System memory is 480 MB (capped at 1 GB)
Video card memory is 64 MB
Streaming SIMD Extensions (SSE) supported
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\system32\opengl32.dll' ): succeeded
...setting mode 4: 800 600 FS
...using colorbits of 32
...calling CDS: ok
...registered window class
...created window@0,0 (800x600)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 8 )
...41 PFDs found
...hardware acceleration found
...PIXELFORMAT 5 selected
...creating GL context: succeeded
...making context current: succeeded
Initializing OpenGL extensions
GL_VENDOR: SiS
GL_RENDERER: Compatible VGA / MMX
GL_VERSION: 1.2.1 SIS 2.11
GL_EXTENSIONS: GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_packed_pixels GL_EXT_polygon_offset GL_EXT_separate_specular_color GL_EXT_texture_env_add GL_EXT_texture_env_combine GL_EXT_texture_object GL_EXT_vertex_array GL_WIN_swap_hint GL_ARB_multitexture GL_SGIS_multitexture
----- CL_Shutdown -----
RE_Shutdown( 1 )
Shutting down OpenGL subsystem
...wglMakeCurrent( NULL, NULL ): success
...deleting GL context: success
...releasing DC: success
...destroying window
...resetting display
...shutting down QGL
...unloading OpenGL DLL
Your video card appears to be missing one or more features required to run Call of Duty.
You should install the latest drivers for your video card, being sure to uninstall the old drivers first. If you already have the latest drivers, you should completely uninstall the drivers and then reinstall them. This fixes most problems. If the game still doesn't work, it may be that your video card does not have the minimum features required. Please check the readme for more information, including a list of supported video cards.
Swjetlo is offline   Reply With Quote
FREE instant scan
Old November 21st, 2004, 04:06 PM     #2 (permalink)
MessiaH289's Avatar
Sounds like you have integrated SiS video with no OpenGL support to me, or something of the sort.
MessiaH289 is offline   Reply With Quote
Old November 21st, 2004, 04:08 PM     #3 (permalink)
skating away.........
doddsy's Avatar
what graphics card do you have?
what drivers are you using?
what version of direct x do you have?
doddsy is offline   Reply With Quote
Old November 22nd, 2004, 02:47 PM     #4 (permalink)
Friedchicken100's Avatar
Send a message via AIM to Friedchicken100 Send a message via Yahoo to Friedchicken100 Send a message via Skype™ to Friedchicken100
looks like graphics trouble. Most of the time thats the problem. Happened to me with tnt2. BF1942 would start up but text would be unreadable.
My other car is a T-34.
Friedchicken100 is offline   Reply With Quote
Old November 25th, 2004, 03:00 PM     #5 (permalink)
Graphic problem
[quote=doddsy]what graphics card do you have?
Adapter:SiS 651
Chip Type:Sis 651 REV 00
Driver provider: SiS
Driver date: 13.11.2002.
Driver version: 6.13.10.2110
DIRECT X: 9.0c
Old November 25th, 2004, 03:10 PM     #6 (permalink)
MessiaH289's Avatar
That's onboard video that most likely doesn't have OpenGL support.
Buy a video card.
Old November 27th, 2004, 08:57 AM     #7 (permalink)
Ehhh
I wish I could but it is Gericom Notebook, any way thanks for trouble.
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
MOHAA or CoD? tony_j15 General Gaming Discussion 33 December 1st, 2005 01:33 AM
so many games out there natbeys General Gaming Discussion 33 September 4th, 2004 11:11 AM
Whats the best game ??? shoaib20022005@y General Gaming Discussion 15 July 17th, 2004 01:19 PM
128mb ti4200 vs. 9600LE klorm Graphics Cards and Displays 31 March 30th, 2004 02:36 AM
Jury Duty vass0922 IMO Community 27 November 4th, 2003 04:15 PM
Is It Just Me? (490)
Connected to LAN but unable to use .. (5)
1 internet. 1 house. 3 computer. ho.. (9)
New Mobo (8)
Folderchat: The Holiday thread (110)
Multiple video cards? (6)
gossip (0)
New Mobo (8)
am2 on 939 (4)
Folderchat Weekday thread (411)
heatsink issue (0)
Hard Core Overclock (5)
getting a keycode through reged.. (0)
1 internet. 1 house. 3 computer.. (9)
xbox setup help. HDMI-DVI-VGA. (1)
