Page 1 of 2 1 2 LastLast
Results 1 to 20 of 26
Thread: xbox live help
    Banned cableuser's Avatar
    Oct 2004
    732
    xbox live help
    Ok I used to have the xbox hooked up directly through the router bu now I want to use it in my basement so i does not use the upstairs tv. I have a computer downstairs hooked up wirelessly to the internet. I put a pci lan card into my computer and put in a cable between the xbox and the card. I have tried bridging the connection but that just makes the internet not work. I think the reason it does not work is because the lan card does not have an ip address. Anyway I want to figure out how to get this working without buying an $80 wireless thing for the xbox or running a coax or lan cable all the way down here. Thanks
    NOTE: I have have used the search button on the forums and did not find anything, and that dsl/ps2 thread just started does not help either.
    Senior Member mike_sanfil's Avatar
    Sep 2003
    986
    First you need to make sure you are using a crossover cable between the xbox and pc, not a patch cable that would run from your router to the xbox or pc. Then the only thing I can think of is to hook up your modem to your computer and use ics.
    Oct 2004
    732
    i am using a crossover cable. And the modem is a cable modem so it has to stay upstairs hence the long coaxle from upstairs to downstairs for the cable modem to work down here
    Sep 2003
    986
    Does the lan card in your computer light up? If you does try going into your xbox and setting up the network settings. If you are using DHCP, it might not be getting though to the xbox.
    Oct 2004
    732
    yes the lan card lights up
    Nottingham, UK
    198
    you need to set up internet connection sharing on the PC. Your ping times might not be too good with that setup though (or they might be fine!) - xbox to PC LAN to PC wireless to router to Net - quite a long trip. Something to watch out for if you get stutters in your games.
    Oct 2004
    732
    ok i got the ip address to work. Now the dns server won't work. I've tried it on automatic but it wont work. I have also set it at the same address as the ip but still doesnt work. If someone could help me with this then i will be able to play!!
    Thanks for your help so far dannychuckle!
    Oct 2004
    732
    anyone??
    Oct 2004
    732
    there is probably a simple solution if someone could help me.
    Senior Member coolguy1986's Avatar
    Oct 2004
    Richmond,Virgina
    917
    What brand is ur router. And make sure u allow the router to give out its Ip because i had the same problem entil i changed the sercuity things.
    3.2ghz HT P4
    1024kingston DDR2
    ATI 9800pro 256mb
    160gb sata raid hd
    Oct 2004
    732
    the router is a belkin wireless 54g. It did give an ip to the card. The ip address works what i cant get to work is the dns server.
    Oct 2004
    732
    i have tried everything i can think of and things people have suggested does anyone else know how to help me?
    just passin thru Sweeper's Avatar
    SW, OHIO
    5,850
    Have you tried looking Here ?
    Oct 2004
    732
    Sweeper If you would have took the time to read what the site you listed said you could see that it does not help in any way with the dns server problem.
  15. #15
    SW, OHIO
    5,850
    Nope... didn't even read it. Just posted it just in case you hadn't been through it. Sorry to have tried to help.
  16. #16
    Oct 2004
    732
    dont worry, what i said was a little harsh. I am sure something easy can be done to fix it and noone knows what it is.
  17. #17
    Member Stick32's Avatar
    164
    What os are you runnin cable?
    "Nothing is ever as bad as it seems, and nothing is ever as good as it seems. Reality is usually somewhere in the middle" - Lou Holtz
  18. #18
    Oct 2004
    732
    win xp
  19. #19
    Oct 2004
    732
    BUMP!!!!
    I still need some help with this as the solution is still not found.
  20. #20
    164
    XP pro or home?
  1. Storing games on XBOX?
    By Martoch in forum General Gaming Discussion
    Last Post: August 22nd, 2005, 09:58 PM
  2. PC Gaming Vs. Xbox
    By help-me-please in forum General Tech Discussion
    Last Post: June 26th, 2004, 10:10 PM
  3. Xbox Connect
    By Gilthanaz in forum General Gaming Discussion
    Last Post: December 31st, 2003, 12:50 PM
  4. Star Wars: Kotor
    By SplitCo in forum General Gaming Discussion
    Last Post: August 16th, 2003, 01:38 PM
  5. Fowarding ports
    By Kory in forum Networking and Internet
    Last Post: June 10th, 2003, 04:41 PM
