Go Back   Tech Support Forums - TechIMO.com > Single and Multiplayer Gaming > General Gaming Discussion
Connecting with Steam Problems?
Currently Active Users: 2607
Discussions: 203,415, Posts: 2,407,361, Members: 248,939
Old December 5th, 2005, 08:46 PM   Digg it!   #1 (permalink)
Alright, well i wanted to start playing Half-Life 2 again since i finally had some time on my hands. So i try starting it up an Steam comes up and wants my password. So i type my password (I know it's correct) and get an error message that says, "Could not connect to Steam network." It's been happening for the last 3 days and still says the same thing. So, i went to Steams website and did everything it said to get Steam to work. I turned off all of my firewalls and it still says the same thing. I don't know what to do anymore. I use to like Steam but its starting to make me mad. If anyone has any idea what to do, please help me!
MDiddy07 is offline   Reply With Quote
Old December 5th, 2005, 08:50 PM     #2 (permalink)
twistedbrntucker's Avatar
Me thinks it was an update issue. Mine went away for some reason.
Work hard to become not to acquire. I didn't work hard to win a million dollars, I worked hard to become Winston Cup Champion. Alan Kulwicki 1992
twistedbrntucker is offline   Reply With Quote
Old December 5th, 2005, 10:30 PM     #3 (permalink)
Banned
evilaznherd's Avatar
Send a message via AIM to evilaznherd
did you check internet connection?
did you ever give out or give a hint to anyone about your password?
(if you did i'm thinking that you got hacked)
did you check your screenname?
evilaznherd is offline   Reply With Quote
Old December 5th, 2005, 10:33 PM     #4 (permalink)
mjolnir1134's Avatar
Is your router blocking steam somehow?
Did you try power cycling your router to see if it worked?
You are, hopefully on broadband...right? o_o;
Throwing ideas... ^_^
EEE 1000H—1.6Ghz—1GB RAM—XP
mjolnir1134 is offline   Reply With Quote
Old December 5th, 2005, 10:37 PM     #5 (permalink)
RetroEvolute's Avatar
Send a message via AIM to RetroEvolute Send a message via MSN to RetroEvolute Send a message via Yahoo to RetroEvolute
1. Completely close out of Steam.
2. Go into your steam directory and delete your clientregistry.blob file.
Don't worry, it won't harm anything... Just re-type in your password after that. It should work again... A glitch w/ Steam that many people have faced.
(If you had entered a bad password it would've told you.)
Intel Core 2 Quad Q6600 OCed 50% (3.6GHz) | ASUS P5K Deluxe w/ WIFI | G.Skill 4096MB (4x1024MB) RAM | MSI GTX 275 | 2x Seagate 160GB 7200.11 RAID 0
RetroEvolute is offline   Reply With Quote
Old December 5th, 2005, 11:23 PM     #6 (permalink)
1. Yes my internet connection is working fine
2. Nope ive never given my password or hinted it to anyone
3. Yes my screen name is fine
Old December 5th, 2005, 11:24 PM     #7 (permalink)
I turned my routers firewall off so that cant be it. Yea i have broadband and im not sure what you mean by power cycling my router?
Old December 5th, 2005, 11:25 PM     #8 (permalink)
I'll give that a try again.
EDIT: Didn't work....
Old December 5th, 2005, 11:28 PM     #9 (permalink)
Could it be that i need to open a port in my windows firewall?
Old August 5th, 2008, 08:47 PM     #10 (permalink)
Steam Connection Error
Thanks for the post about renaming the clientregistry.blob file! It solved my connection problem and really should be in Steam's troubleshooting guide!
Almightyrecht is offline   Reply With Quote
Steam CD key problems. [Neo770] General Gaming Discussion 31 July 29th, 2008 05:15 PM
Problems with Steam? FatalException General Gaming Discussion 1 February 17th, 2005 10:06 PM
Connecting to specefic IP in Steam? CJDMaster804 General Tech Discussion 2 July 2nd, 2004 07:13 PM
Having problems connecting-HELP! f1oored Networking and Internet 4 March 26th, 2004 07:11 PM
Connecting problems Sadain Technical Support 4 February 22nd, 2003 09:11 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Is It Just Me? (3716)
nVIDIA GTX 260 vs ATI 5770 (5)
Superbowl commercials (The green po.. (15)
and she wanted to be VP? (42)
GPU upgrade from 8600 GT (11)
New PC Heavy Gaming Rig (8)
[F@H Chat]2/6/10 New thread for ya'.. (22)
Need for Speed Shift (7)
Best route for upgrade (several opt.. (5)
Motherboards with 2 PCIE x16 slots (8)
Graphene transistors promise 100GHz.. (7)
I want to buid a pc with this case (14)
Animated GIFs don't animate? (13)
Upgrading (5)
Microsoft Wireless Keyboard 3000 (13)
Laptop - HDTV Connection Using HDMI C.. (2)
How Good is This $450 MSI Laptop? (3)
HD5870 Question (16)
[F@H Chat]2/6/10 New thread for ya' s.. (22)
Wireless G printer w/wrt160n (0)
SpeedFan Temp Monitor Help (3)
BSOD - IRQL not less or equal - HELP! (0)
Unable to find LAN (7)
Best route for upgrade (several optio.. (5)
should i upgrade whole pc or just vid.. (2)
WEBCAM / XP / XP64 / VISTA (7)
routers and switches OPERATING SYSTEM.. (0)
One dumb nube and a cisco 3550 (1)
120mm fan on top of case??? (12)
Is my hard drive going bad? Please h.. (2)
rsync over passwordless ssh in a cron.. (4)
Wii at buy.com for $374 - Carnival Sm.. (7)
Deleted email addy keeps bouncing bac.. (1)
Video Format Total Solution: How to C.. (0)
wireless connectivity (0)
