NEED For SPEED Most Wanted: Crashes to Desktop: Please Help  | | |
March 8th, 2009, 01:27 AM
#71 (permalink)
Which is the onboard chipset? |
March 8th, 2009, 06:43 AM
#72 (permalink)
| What is this win98? is it the windows 98? I'm using windows xp My problem is my computer crashes to desktop every time i win a challenge or quick race. And in career mode, on the 5 level again with razor on approx. 66% the tires do "hu,hhu,huu" and it crashes to desktop PLEase help me! i'm using a cracked one Quote:
Originally Posted by Forrykook G'day all
After my previous post I then went and had a computer upgrade and also bought NFS Carbon. New system should play everything.
Gigabyte GA-P35-DS3L
Core 2 Duo 3Ghz cpu
Geforce 8600GT 512MB
4GB RAM, (though XP only reads 3.5GB)
Audigy 4 sound card
Sh!t hot sh!t hot sh!t hot yeah!!!
Anyhow, NFS Carbon began to crash also. I found somewhere on the net to run it in compatibility mode for Win98. It works!!! It never crashed after that. I've re-installed NFSMW but haven't yet played it. Hoping it will work for that too.
So there you have it, run the game in WIN98 compatibility mode.
Cheers
Forrykook | |
March 8th, 2009, 09:26 AM
#73 (permalink)
You're using a cracked copy??? What a nerve!! Go and buy a real one. |
March 8th, 2009, 09:29 AM
#74 (permalink)
| | A hero in training
Yes we don't support cracked games here |
May 12th, 2009, 06:36 AM
#75 (permalink)
| NFSMW crashes when the game is played in between
Dear frndz,
When i installed the nfsmw ,i was able to play the game but in between the play the game crashed and it is persisting .i disabled te firewall weter to chek for it is the cause but it still persists.pls advice. |
August 24th, 2009, 02:40 AM
#76 (permalink)
| NFS Most Wanted
Plz, tell the full PC configuration so that I can find out any hint to solve ur problem.
Um..
Just a minute. Here, I have written the Requirements for NFSMW.
* Windows 2000 or better
* 1.4 GHz CPU
* 256 MB RAM
* 3 GB hard disk space,
* DirectX 9.0c compatible 32 MB video card with one of these chipsets Radeon 7500; Radeon Xpress 200; GeForce 2 MX; Intel 915; S3 GammaChrome S18 Pro
* DirectX 9.0c compatible sound card
Does you have all these compatible or better machines.
My NFSMW is portable.
What's ur? Is it a Setup? and What are the contents in CD (If you have a cd to install.) or the contents of the folder from you install the game.
My one is like - I have 22 RAR extractable files. in which one is Executable and Extractable file thru which I run the setup.
the game asks me to insert a CD.
A Daemon tool to mount the Image file of the game. which gets installed at the installation folder thru Setup. Its a imaginary disc.
After that I run executable file named as "Safe Disc 4 hider.exe" or "sd4hide.exe" . A dialog box appears, first I click on Restore and the click on Hide.
These buttons will display simultaneously as I click on it. Close that Dialog and then I run the game. |
October 26th, 2009, 04:59 AM
#77 (permalink)
hey i have the same problem but i solved it dont place that d3dx9_26.DLL file in the system folder place it in your nfsmw wanted that is where u installed the game hope it works because it works for me....if it works reply to my mail danny2mar91@gmail.com |
October 26th, 2009, 05:02 AM
#78 (permalink)
| Quote:
Originally Posted by havoc90 Hi all,
I registered onli bcos i saw an error message from sapam.My NFSMW has an error wif the d3dx9_26.DLL.I think it is a direct X file.I tried 2 download it and put it in C:WINDOWS/SYSTEM but it keeps on crashing.Like sapam said,there is a splash of the NFSMW and the thing goes into full screen.Then after a few minutes they giv a message WINDOWS,SYSTEM ERROR,PLS SAVE ALL DATA AND REBOOT COMP 2 HAVE FULL FUNCTION.  When i click ok, the screen goes into a 4-bit colour mode and everything is turned big like resolution 800x600.Help pls if any1 knoes how 2 fix it!!!!  |
