Thread: Problem with cd drive
December 29th, 2005, 02:41 AM #1Junior Member
- Dec 2005
- 13
I dont know what i did with out this place. for some reason my disc isn't being read. Anything i could check?
December 30th, 2005, 04:58 AM #2Banned
- Dec 2005
- 1,465
First examine the disk for any scratches, smudges, or any signs of not being even across
the surface from possible exposure to heat. Try a lens cleaner to make sure the drive itself
is free of dust and any possible debris from placing and removing disks from the drive. One
other immediate idea is to try several other disks in the same drive as well as trying the cd
you are having problems with in another even on another system to see if it is defective.
December 31st, 2005, 01:26 AM #3Junior Member
- Dec 2005
- 13
yeah other disc worked so I don't think it is the drive any more. But i'll try the disc cleaning any stuff.
January 2nd, 2006, 03:56 AM #4Member
- Aug 2005
- 151
Also try starting thread about CDs and CD-Drives in the correct hardware or media topic areas.
Desktop: Athlon X2 4200, 2GB, 768mb GTX460, 320GB
Laptop: HP Dv6: Phenom II n930, Radeon HD4250 + Radeon 5650, 4GB, 500GB
CD drive problem
By fakan in forum Technical SupportReplies: 13Last Post: April 11th, 2005, 02:33 PM -
cd drive problem
By londoner in forum General Tech DiscussionReplies: 14Last Post: January 3rd, 2005, 04:00 PM -
CD Drive Problem
By J'rd in forum Technical SupportReplies: 3Last Post: October 6th, 2004, 03:36 PM -
CD-R drive problem
By Lychgate in forum General Tech DiscussionReplies: 2Last Post: March 18th, 2004, 03:53 AM -
Parallel Zip Drive with Windows XP - problem recognizing drive
By SUpitch15 in forum Storage RelatedReplies: 5Last Post: December 18th, 2002, 06:39 PM
There is about 3cm space between the cards :)
Temps too high? ( GTX 580s )
