Results 1 to 10 of 10
    Member williams22's Avatar
    May 2003
    Vermont
    224
    Problem playing C&C Generals
    I just purchased a new Inspiron E1405 and the game C&C Generals. I installed the game but cannot get it to load past the splash screen, it freezes every time. Any suggestions? I'm running DirectX 9.0c.
    - Chris Nemlich
    AIM: bluedevils2223
    E-mail: cmn36@cornell.edu
    Ultimate Member Whos Theo?'s Avatar
    Aug 2004
    Fort Richardson, AK
    1,034
    That recently happened to me and I got it working by repairing the installation.
    Oct 2003
    Canada [Maritimes]
    1,260
    http://www.dell.com/content/products...n=specs#tabtop
    could be the on board graphics's giving you problems
    try updating the drivers for it
    Senior Member CoonDawg's Avatar
    Feb 2005
    Michigan
    629
    Well, your first mistake was buying an EA RTS...
    // E6400 @ 2.80ghz // 7600GT @ 590/720 // 2GB Patriot DDR2-800 //
    NOVA
    33,806
    46
    Thanks for the help CoonDawg im sure your remark was insight and helpful at the same time to everyone who reads this post. espically the creator of the thread
    Do you have the latest updates for the game intstalled? Latest video drivers?
    Aug 2004
    Fort Richardson, AK
    1,034
    Quote Originally Posted by CoonDawg
    Based on this information, I'm coming to the conclusion that you haven't even played it.
    Back to giving some useful information, you could also uninstall and reinstall it and see if that works.
    Feb 2005
    Michigan
    629
    Wow, you two take jokes well.
    As for actual advice (not that my first one wasn't real advice), have you previously installed the game on another computer? It could possibly be a defect or scratch on the disc, however rare that may be.
    Also, there may be a conflicting compatibility that a patch may have fixed. But then again EA doesn't patch games so you may be out of luck.
    Ultimate Member wera's Avatar
    Aug 2005
    3,297
    CoonDawg pepole here are really bad at being ....i can'tthink of the word... Normal? Just th e word sex makes theam get all up in a hissy fit.
    Anyways.
    Have you updated the graphics drivers?
    Try running memtest 86 http://www.memtest86.com/
    Have you reinstalled the game?
    Try a repair installation.
    Is the game patched?
    More specs on the syste mwould help .
    Banned Keymaker's Avatar
    Jan 2005
    Loveland, CO
    5,490
    2
    Wink
    I run this game on my 8100 Dell notebook. It currently has a 32 MB NVIDA 2 go card.
    Direct x 9.0c too!
    I wonder if you should go to the options in the game and try lowering a lot of the settings to see if that works. Then, increase them until the problem occurs again.
    However, I just realized that you can't get it to load past the splash screen. Do you mean after it says " EA GAMES"?
    Have you went into dxdiag to see if you have problems? IE: dxdiag typed into run.
    Maybe turning off hardware acceleration in the video card properties might help.
    Jan 2005
    Loveland, CO
    5,490
    2
    I believe I have duplicated your problem.
    I recently installed CC Zero on the notebook and forgot that I saved the CC Generals Zero Hour Data folder in My documents from the desktop. Well after I installed I ran the game. The first two screens came up and then a window appeared saying something like, I needed to upgrade Directx or the video card was not compatible.
    So I realized that perhaps the CC Generals Zero Hour Data folder had something to do with it, as there are settings in there that reflect my desktop and not this notebook. I deleted the whole folder and restarted the computer. Now the game works fine. I should have just saved the 'save' files from the desktop instead.
  1. C&C Generals Prob....
    By Dsword in forum General Gaming Discussion
    Last Post: June 12th, 2003, 06:28 AM
  2. C&C Generals
    By phrozen_dreamz in forum General Gaming Discussion
    Last Post: April 9th, 2003, 09:08 AM
  3. C&C: Generals!!!!!
    By jrock in forum General Gaming Discussion
    Last Post: February 27th, 2003, 03:28 AM
  4. c&c generals
    By ferg111 in forum General Gaming Discussion
    Last Post: February 16th, 2003, 08:30 PM
  5. c&c generals
    By ferg111 in forum Applications and Operating Systems
    Last Post: February 15th, 2003, 10:28 PM
