Results 1 to 7 of 7
    Warcraft III LAN problem
    On my computer, I can create a game in Frozen Throne using LAN, and one other computer in my house can join it, but my brother's computer cannot. He doesn't have any such firewalls to speak of, and I installed it on his computer the same way I did on mine. Every time he tries to create a game, it says "Game was not found." I've been trying everything to fix this, but I've got nothing left to try. If anybody can help, that'd be terrific.
    Oct 2008
    Quote Originally Posted by JamesMason0 View Post
    Apr 2009
    Thumbs up SOLUTION
    you might have more than one firewall...
    I once had the same problem,.. if your brother's computer has an extra firewall like McAfee, i suggest you to uninstall it. hard to believe.. it is this firewall that blocks warcraft LAN play. If you cannot uninstall firewall within the computer, get the firewall uninstall software/program from the internet.
    OR
    if your brother's computer has firewall turned "on" in its control panel, turn it "off" and casually expose your computer to external softwares while playing warcraft. BUT MAKE SURE TO TURN IT BACK "ON " AFTER YOU PLAY, OTHERWISE your computer might be at risk any point you use the internet.
    if it helps.....
    enjoy
    icer-zerocool Dj-Icer's Avatar
    May 2003
    Arakwaku, Tokyo!
    3,203
    Is it just Warcraft 3? How about other LAN games?
    You can copy the whole Warcraft 3 folder, which would be around 4 GB. So you have to find a pendrive with a bigger capacity to transfer that easily. Paste in your brother's computer. Try run it.
    Feb 2010
    Angry reply
    i have the same problem !
    Thanks! After refering to this thread, I realized that my Kingsoft Firewall cleverly block war3.exe, causing the problem.
    For me the problem is fixed.
    I still cant do anything!(same problem)
    how do i do this?? even though i turn off the firewall its still the same?
    please help me
    Facebook.com/kingmelly
There are currently 2 users browsing this thread. (0 members and 2 guests)
  1. Warcraft III
    By CrazyCase in forum General Gaming Discussion
    Last Post: October 25th, 2002, 11:53 PM
  2. Warcraft III HELP!!!
    By Sweeper in forum General Gaming Discussion
    Last Post: September 14th, 2002, 08:38 AM
  3. FS: Warcraft III
    By Mike in forum Traders Forum: Buy, Sell, Trade
    Last Post: September 5th, 2002, 05:05 PM
