Using PS3 with Sprint Mobile Broadband USB Modem
Hi, sorry if this is in the wrong forum, please move it if it is.
Ok, heres the deal. I have this :
http://www.sprint.com/business/produ...PcsPhones.html
Its like a wireless internet card that connects through the USB port. And my question is, is there any way I can set this up as an access point to use it with my PS3? See I live out in the middle of nowhere and this is the closest thing I can get to high-speed internet, and it works pretty well, otherwise all I have is dial up =/
I dont think theres anyway I can set this up to use it, but I could be wrong. Ive seen people hook up the PS3 and use it with dial up, so maybe theres some hope :P. does anyone else have this, or has anyone else tried using this? Thanks in advance.
PS3 mobile broad band connection
I fallowed all this step but after that I got the following error "IP Address timed out", but I manage to fix it and I'm going to detail what I did.
I have a Sierra Wireless card Compass 597 and I'm using Window XP ( I need to try this with Ubuntu)
1) Go to --> Start
--> Control Panel
--> Network Connections
2) Now select the mobile broadband connection (mine was called Mobile)
--> Right-Click on it
--> Properties
--> Advanced
3) At the bottom theres the "Network Set Up Wizard" --> Click it
4) Press --> Next
--> Next
--> Click in the box that says "Ignore disconnected network hardware" and press Next
--> select the first option "This computer connects directly to the Internet. The other computers
on my network connect to the internet through this computer"
5) Choose the mobile connection e.g
Mobile Sierra Wireless Compass 597 EVDO Modem #3
--> Click Next
6) Now choose the private connection.
- In order to connect the PS3 to the computer you need a 'Lan connection'
mine was " Local Area Connection (Lan)"
--> Click Next.
7) Give the Computer a description or name
--> Click Next
8) Name the Network
--> Click Next
9) File and Printer sharing (its up to you if you want to share it or not)
--> Click Next
10) Then Click Next and the change will be done.
11) Go again to step 2 and Under "Network connection sharing" check the box that saids:
"Allow other networks users to connect through this computer internet connection".
Then in the Home Network Connection bar choose the Lan connection that you created in the Wizard.
In my case "Local Area Connection"
I left my IP and DNS in auto acquire for the Lan and the Shared Mobile connection. I hope this help to the people that got the timed out error (just like myself). If this work and you able to update the PS3 try to restart the PS3 because after I updated it the error happen again but after I turned of my laptop and PS3 everything was ok again.
