Results 1 to 17 of 17
    Jun 2002
    240
    Unhappy counter Strike Problem!!!
    Ok, I just bought the ORIGINAL half-life, installed it, got the patch (1.1.1.1 or something) and installed it, i download CS and DoD, i installed them, i go into CS and go to Play Online, I then click the Update button to bring up the servers, and then it runs throough all these server names, goes back to the main screen (the screen after you click Play online...with the box where the servers should be) and nothing is there, i wait 5-10 mins, NOTHING
    How do i escape this misery? (ANY HELP???)
    thank you and bye (same problem with DoD)
    stu_waZ_here (and he liked it)
    I am a banana! originel's Avatar
    Jun 2002
    Texas Tech
    3,921
    what filters are you running? it sounds to me like you set some filter that ruled out everything. also you could always re-install cs, no biggie.
    Jun 2002
    240
    Filters
    I am running the filters that seem to make sense, they wouldn't have a filter that blocked everyhting out, well that wouldn't make sense
    thanks for posting
    (at the bottoms it lists number of server but says 0 players) ???
    Jun 2002
    Texas Tech
    3,921
    hmm, that's strange. ok so i don't think its the filters anymore. are you connecting through wingate(or any other proxy software) by any chance? it did this to me before i got my router.
    Member THE V_I_R_U_S's Avatar
    Nov 2001
    Texas
    470
    I just never turn on any filters. Its supposed to take ahwile to get the server list. In fact, a LONG time, unless you have T3 But you dont have the little download server list window do you? Maybe it can't connect to the network? Hmmmmm.....
    Jun 2002
    240
    Question Ummm?
    Ummm, I'm not sure what you mean, i have
    Sympatico DSL
    and i don't think i checked off and proxy stuff in the Filter menu
    thanks again and bye
    Alberta, Canada
    563
    are you waitng a FULL 5-10 minutes? (you shouldn't have to, but I have to ask...)
    reason I ask is mine does basically the same thing: the whole time it's updating it says 0 players online at the bottom, then the update finishes and quite often theres nothing listed, but in about 1 - 3 minutes (a "full & honest" 1-3 minutes, I'm very patient!! ) the list shows up...
    also, is it showing the names of servers in the smaller window while the update runs?? if not then somethings might not be right...
    ciao...
    Alberta, Canada
    563
    also, I'm on cable (with a p3-500) and to do a complete update of just CS servers it takes over ten minutes... last time it was around 680 seconds till finished updating....
    Jun 2002
    240
    Talking thanks!
    Ok, i will tyr clicking all the filteres off and honestly waiting 5--10 minutes, thanks and i will report back
    Jun 2002
    Texas Tech
    3,921
    if you use DSL, and connect directly to it, then no, your not using what i was thinking.
    Athens, GA
    1,333
    in ur filter, make sure you dont have half-life slected for the game type and a counter-strike level or some mismatch like that....i have done it before.
    ummm
    Alberta, Canada
    563
    well, it shouldn't take any more than 3-5 minutes from the time the update finishes, to the time the servers are displayed. but (for me anyways) it does take a couple minutes for them to display...
    I have only "Game=Counterstrike" set as a filter and I believe I get over 20,000 servers back...
    g'luck!
    Jun 2002
    240
    thanks Guys
    Hey, it worked, turned off all the filters and just waited
    thanks
    Alberta, Canada
    563
    also, in your "half-Life" folder, find the file "favsvrs.dat" and see how big it is. this is the list of servers. Mine's over 12MB!! if you want you can also open it with notepad to see if there are any entries in it, but if it has any size(kb's/mb's) then there should be something in there...
    if you really want, I can email you my favsvrs.dat file, don't worry, it's only 620KB zipped!!
    cheers!
  15. #15
    Alberta, Canada
    563
    doh! me too slow...
    well, happy fraggin'!!
  16. #16
    Dec 2003
    9
    just download steam
  17. #17
    Ultimate Member ben-the-slacker's Avatar
    Nov 2001
    Starkville, MS
    1,452
    Thread: Resurrection
    However much I hate Steam, it's about the only solution now, since WON is getting phased out.
